How do i remove my dash rail pads??
Dash Rail Pads
minimad91
, Jan 05 2013 08:03 PM
3 replies to this topic
Posted 05 January 2013 - 08:03 PM
Posted 05 January 2013 - 08:09 PM
Top one has 3 nuts holding it in but can be an arse taking top one out with out window screen being take out can be done i got violant with mine and puah window screen out luckly got caught on wipers :)
Posted 05 January 2013 - 08:10 PM
The top one has bolts underneath it have to remove. It's hard to remove it gently with the screen in so may require some brute strength.
The lower is a bit more complicated. You have to remove the switch panel in it. IIRC there are some 1/4 bolts behind there and it wil come out. Watch out for choke / heater cables. Then there is a silver trim to remove on top of the lower pad. This has clips and is very easy to bend. Take care. It is also glued down so will come of with a bit o tuggin'
Posted 05 January 2013 - 08:15 PM
Last thibgs to come out so will have another look
