Been offered a loan of a plasma cutter for as long as its owner doesnt need it, thinking it would be handy for cutting out my boot floor etc, but how does it cope with mini paint? i am assuming the underseal will burn the same way it does if you try and weld it?
Anyone with experience or tips to share?
How Does A Plasma Cutter Cope?
jamesy
, Jan 06 2013 07:44 AM
5 replies to this topic
Posted 06 January 2013 - 07:44 AM
Posted 06 January 2013 - 07:59 AM
you need clean metal. or at least to start with. we clean the metal with grinder first.
Posted 06 January 2013 - 08:03 AM
Better invest in a couple wire wheels for the grinder then? never used one before. aparently its needing new tips and nozzle, are they all the same or make/model specific?
Posted 06 January 2013 - 08:42 AM
I use a flapping disc to clean metal back usually.
plasma is a great tool, you need a steady hand or use something to rest againist to do a straight line.
Posted 06 January 2013 - 09:16 AM
We bought a plasma cutter and the 2 time we have used it, it's been great.
Like Jordie said, to start off with you will need a clean part of metal, but when it starts it goes through paint and seam sealer easily, although it did struggle a little when it came to the subframe re-inforcing plates in the boot floor as they where quite think - but we didn't change any setting's so perhaps that would've helped.
Hope this is of some help to you
Posted 06 January 2013 - 07:17 PM
you need reasonably dry air (compressor), if it's too wet then it won't arc.
