92 Mini City
285 replies to this topic
#136 Marco1972
Marco1972
  • 822 posts
Posted 18 November 2016 - 12:59 PM
Small update
Been rather busy of late so haven't managed to get on with the doors
I've started to get some of the parts powder coated
I'm using the same company that did all my lads stuff as they are very reasonable and do a good job
Collected these today
Rad cowl , top engine steady , clutch slave bracket , fuel line shield , rad bracket , horn and coil bracket and a bit which holds the battery cable in place
Getting the front subframe, suspension trumpets and a few other bits in later this week
Mark
Edited by Marco1972, 18 November 2016 - 05:58 PM.
#137 Daz1968
Daz1968
  • 2,058 posts
Posted 18 November 2016 - 05:36 PM
Looking good, who did you use for powder coating as I need to find somewhere to do my su frames and various parts
#138 Marco1972
Marco1972
  • 822 posts
Posted 18 November 2016 - 05:57 PM
I use washford finishings 01527525936
Bartlett. Rd B98 ODQ
Mark
#139 Marco1972
Marco1972
  • 822 posts
Posted 04 December 2016 - 10:21 PM
Update
Had the front subframe powder coated
With that done it was back to the door
Ground down the welds with a 1mm cutting disc
Applied several coats of primer and top coat this should keep the rust at bay
With that done on went the new Heritage skin ( I fitted a sound proofing pad to the skin before it went on )
Door fitted back to the car
Not too bad it will require some weld rod at the top by the door handle
the bottom by the A panel needs a wee tweak but I'm very happy for the first fit
Thanks for looking
Mark
#140 Daz1968
Daz1968
  • 2,058 posts
Posted 04 December 2016 - 10:46 PM
Looking good
#141 Marco1972
Marco1972
  • 822 posts
Posted 13 December 2016 - 07:20 AM
Door number 2
Stripped it down and removed the skin
Not as bad as the other one but a fair bit of work to do
Mark
#142 Marco1972
Marco1972
  • 822 posts
Posted 18 December 2016 - 09:13 PM
Back to the door today
Cut out all the rot bit more involved than door 1 due to a few holes in the bottom as well as the lip
Rusty lip removed
Then I cut out the rot in the bottom of the door
Cut some steel and welded it in
Welded it from inside to keep it tidy on the bottom
Ground it down
Then made up the new lip and tacked it on
Dressed it all up and gave it a splash of zinc primer
The light was fading so I left it there
Got to do the drain hole bit more lip and some final dressing then I can fit the skin
Quick pick of the rest of the bits I had powder coated
Mark
#143 blueovalcraig
blueovalcraig
  • 193 posts
Posted 06 January 2017 - 09:39 AM
I feel your pain with regard to working outside.  My driveway is on quite a slope too so it's not easy.  Between that and two kids I haven't been able to do much to my mini.  Told the wife that I'm getting a digger in to level the driveway this summer!
#144 Marco1972
Marco1972
  • 822 posts
Posted 06 January 2017 - 07:42 PM
I hope to have this finished by this summer not much welding left to do
I'm into my 5th year with this build !!
Don't think I'll be doing another one any time soon
Mark
#145 cityspeed
cityspeed
  • 193 posts
Posted 06 January 2017 - 08:37 PM
I think I'm on my 6th or 7th year and have only just started , so don't worry about it to much your flying in comparison!
I've got similar rust issues and have the same panel's to do as yours, just started following as your pics are really handy, keep up the good work, thanks, Jay
#146 Marco1972
Marco1972
  • 822 posts
Posted 07 January 2017 - 03:45 PM
Cheers Jay
Glad you find the pics useful
I brought this car expecting to just use it as it looked good and was one of the best I'd seen for the price
But all that shines isn't gold !
My knowledge of these cars wasn't that comprehensive 5 years ago and in hindsight I'd of continued looking but hey ho it's been a learning curve with lots of highs and plenty of lows
Cheers Mark
#147 Marco1972
Marco1972
  • 822 posts
Posted 21 March 2017 - 03:54 PM
Update time
Had a bit of a step backwards moment recently
I looked through my thread and wasn't happy with some of my early work especially in relation to the drivers door step and seat crossmember repairs
Sooooooooo this happened
Chopped out the door step and crossmember and removed all the sound deadening
Luckily I had another much better door step from sonic so that will be going on and I got the crossmember from M machine Minispares only sell the magnum ones
I had a small area to repair then I prepared the floor and crossmember
Feel better about it now just got to finish the plug welds and dress it all down
Also found a new paint shop that's given me a very good price so if all goes to plan it will be painted next month
Mark
#148 Marco1972
Marco1972
  • 822 posts
Posted 19 September 2017 - 08:12 AM
Hi all
Not updated this for 6 months
Well a lots happened but I'm happy to say all the metal work is finished and it's gone off to the body shop and it only took 5 years so far
I'm just in the process of sorting out Photobucket as it seems to have gone nuts lately for some reason ??
So I'll update with some pics shortly
Going to be rebuilding it on the drive at home not ideal but lost my garage space but hey ho onwards and upwards
Mark
#149 blueovalcraig
blueovalcraig
  • 193 posts
Posted 19 September 2017 - 10:50 AM
Hi Mark, good to hear from you and look forward to seeing your photos of the rebuild.
#150 Marco1972
Marco1972
  • 822 posts
Posted 19 September 2017 - 11:59 AM
Thanks mate
Nice to know folks are still interested in it
I guess it's easy to get lost on here when you disappear for 6 months
