92 Mini City
285 replies to this topic
#91 Marco1972
Marco1972
  • 822 posts
Posted 26 January 2016 - 08:48 AM
Looks great cant wait to get my next sill on my car... Top work pal!
Cheers bud :-)
#92 Marco1972
Marco1972
  • 822 posts
Posted 07 February 2016 - 07:16 PM
Managed to get a few hours in on the car today and what a mixed bag it was
I wanted to get the inner wing finished and put the A panel back on but best laid plans n all that .....
Started of by making up the panel for this area as its been on the to do list for ages
E7D897E9-C987-434F-85A8-94C76222FAF5_zps
EFD66C49-FE3D-40FA-9AE5-DADA6A0227F6_zps
54C2EFB3-327A-4FA3-8CA0-E317F31914C8_zps
60E502F6-E960-459B-8CE5-271F5E0965D5_zps
Held in place with inter grips and tacked in
975E68D1-EF54-4D94-9FC7-1067431CB056_zps
Dressed up and given a coat of zink primer
966B33FD-F54D-46A1-A362-014FB2B17DF8_zps
Got a small piece to make for the bottom lip and finish welding on the inside
I was asked about the scuttle closing panels and I assumed they had been replaced as the front end was new but this has proven not to be the case
I was cleaning off the old under seal with a twisted knot wheel when it dislodged a chunk of sealant which revealed a hole in the closing panel .... Bugger.......
Looked like this before I took the sealer off
49955BD2-DBCF-46CC-A7D1-119AEB817F43_zps
To say I was a bit peed off would be an understatement I had visions of having to remove the wing which would of buggered it I felt like throwing the towel in !!!
Still can't understand why whoever replaced the front end left the crappy old closing panels in ???
Any way after much cursing and head scratching I decided to chop it out I had decent access as the A Panel is off
I slit it with the grinder and basically ripped it out bit by bit
Ended up with this
A6FF9087-C93D-44F5-9D7C-1C53876EBCFC_zps
065EE1DE-3044-400A-9301-0DAF80B41FEC_zps
After a coat of zink
350D7C3F-4BA6-49B7-AFA7-6B86C0C68B47_zps
The old closing panel 😃 Not a lot left of it
60A29CB1-12BD-42FE-B78F-75AD785FD3ED_zps
I plan to drill a few holes and plug weld the new one in from inside the car that with a few tacks along the edge where it meets the bottom of the scuttle should do the job
Bit of a pain in the ass but hey ho just hope the other side is ok
I removed the charcoal canister bracket for more access don't think I'll be replacing it as its for the later model no idea why it was fitted in the first place bit of a waste of metal if you ask me
E39522E9-1252-4E52-BE5C-9EB65D3632F1_zps
That was it for today one step forward and 20 back .......
Edited by Marco1972, 07 February 2016 - 09:50 PM.
#93 lawrence
lawrence
  • 1,341 posts
Posted 07 February 2016 - 08:15 PM
What did I tell you about the closers hmm? :P glad you checked tho, would hate for your hard work to be undone
#94 Marco1972
Marco1972
  • 822 posts
Posted 07 February 2016 - 08:28 PM
I did think of you when I discovered this little cherry
You cursed me lol
#95 lawrence
lawrence
  • 1,341 posts
Posted 08 February 2016 - 07:25 AM
Aww how sweet :) it's becuase it happened in my project too. To cut corners the previous owner didn't replace mine leading to the scuttle end rotting out on the ns which I then had to replace.
Cost cutting seems to kill minis :(
#96 Leesey
Leesey
  • 37 posts
Posted 09 February 2016 - 04:48 PM
Just read this from start to finish and it is amazing what you have done with the mini!
A real inspiration
#97 Marco1972
Marco1972
  • 822 posts
Posted 21 February 2016 - 04:38 PM
A real inspiration
Thanks Leesey
#98 Marco1972
Marco1972
  • 822 posts
Posted 21 February 2016 - 05:14 PM
Right then
It was back to it today I've now got a new closing panel from Minispares
I did have a moment of Madness and got a magnum panel but the fit was laughable so it went straight back and got changed for the genuine article
CE9D9214-F14C-4DEF-A1BA-D75A6C278301_zps
This will be fitted soon as I had a bit of a moment and decided to remove the engine and subframe !!!!!!! :-)
78AD52F2-BD4C-4C4B-B10E-B0EB6795E2AF_zps
As you can see I'd been removing some of the ancillary parts for powder coating so the exhaust servo and rad were already out
I've took pics of where the wiring loom attaches for reference when I put it back together
3ED31A8C-5A66-4EE7-B0F0-BFA2D9F3161D_zps
8ED4C51C-EF9F-48DA-AF50-0E49AC712197_zps
C5C0192F-94F1-4786-98FA-489805F4A62C_zps
A0C68E76-D700-4F04-ABB1-158CB0ADC539_zps
Then we set about removing all the remaining cables and hoses followed by selector shaft pin and bolt ,shock absorbers track rod ends and finally subframe mountings
AC84F025-E2DA-4BEB-AB23-6E10151AE712_zps
4 pairs of hands later it was out
2C1CD92A-F849-469C-AD4E-4C393201FFA8_zps
52D16B41-5F1B-4D55-9931-AB1088F40AA2_zps
My plan was always to remove the engine at some point to degrease and paint the block also to replace the drive shaft seals and a few gaskets this will also allow the engine bay to be done when I get it sprayed
I've also discovered that one of the cv boots is split and so is the steering rack gator so more bits to add to the list of never ending parts
Mark
Edited by Marco1972, 31 March 2016 - 10:53 AM.
#99 Marco1972
Marco1972
  • 822 posts
Posted 30 March 2016 - 04:03 PM
Quick update
I've degreased the engine and it came up quite well
61E1799E-E2C5-4852-BFC8-06F9A5DC18D9_zps
19FAB50C-7BBD-4EBA-96EA-C618D70A1B01_zps
C17102BA-9BCB-46FD-8A76-801D069EF072_zps
30CABD63-352C-400D-8790-BD8FB650B0F1_zps
Still got some of the ancillary parts to remove to get to the last bits of grime
I will be replacing all the usual leaky gaskets and seals and it will get a lick of paint
Going to need a new CV boot and rack gaitor
104728DC-811C-4718-9245-14C2AA41B5EB_zps
B10ED2A7-CD70-4413-92CF-4639F61E57E3_zps
I've also removed the loom ready for the final strip down before paint
I've took the time to record where all the wiring goes but to be honest these looms are pretty basic the pics are for reference only
0BD1EEFD-6224-4C29-AAFE-877B0A1461DB_zps
75AED0A9-8228-463D-8F73-9FC1C652FC44_zps
E69F6F43-B661-44EC-BB2A-CE68D0F46418_zps
0043CF53-9D5E-4D88-8C74-3D9903F2FE24_zps
Then it was time to replace this little fella
Had some work to do in the fresh air vent area first as there was some corrosion behind the old closing panel that was out of sight
BD386DA0-E44C-430F-9C30-988EA24DCC11_zps
Bit more tidying up and this will be fine
Closing panel in just needs tidying up and painting not the easiest of jobs with the wing on but hey I like a challenge
A35FE985-10CE-4515-A809-EC4E7A618BE0_zps
#100 blueovalcraig
blueovalcraig
  • 193 posts
Posted 30 March 2016 - 11:01 PM
Have just read the whole thread. Great work! Love the determination and enthusiasm
#101 Marco1972
Marco1972
  • 822 posts
Posted 31 March 2016 - 10:56 AM
Thanks for taking the time to read through
Mark
#102 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 March 2016 - 03:51 PM
Those closers are a bit of a pain to fit with the wings on. The worst part i found was getting the old one out.
Good progress on this. Are you changing the colour?
#103 Marco1972
Marco1972
  • 822 posts
Posted 31 March 2016 - 08:52 PM
Hi Ben_O
Think I'm sticking with Henley blue maybe a different roof colour but I'm trying to stay as close to standard as I can so who knows
Just want it finished mate gone on far to long
How's yours coming on
Mark
#104 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 01 April 2016 - 07:13 PM
Hi Ben_O
Mark
Good about the Henley Blue. It looks really good when it is fresh. Here is one i have just finished at work :-)
Mine is still at a stand still, rotting out under a tarp on the driveway. I need to get it into work and carry on with it there but we are moving the bodyshop into  new unit so everything is too upside down to even think about it yet.
Ben
#105 Marco1972
Marco1972
  • 822 posts
Posted 01 April 2016 - 09:37 PM
Hi Ben_O
Mark
Ben
Takes me back to when I first brought mine bud
Little did I know it would still be in bits 4 years later
http://i1355.photobucket.com/albums/q712/Brittle1972/image_zpsf433dc55.jpg[/IMG[/URL]
[URL=http://s1355.photobucket.com/user/Brittle1972/media/image_zps9246a15e.jpg.html][IMG]http://i1355.photobucket.com/albums/q712/Brittle1972/image_zps9246a15e.jpg
