Max Bore 998?
10 replies to this topic
#1 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 06 January 2013 - 08:16 PM
I was looking at getting my 998 bored to +60 thou.
But I have read that a 998 can only be safely bored to +40thou.
Can anyone shed some light on this for me?
I have limited knowledge, so please bare with me.
Many thanks, Jack
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 06 January 2013 - 08:22 PM
http://www.theminifo...ig-is-my-engine
plus 60 should be fine, sure I've even read of very rare plus 120 thou
#3 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 06 January 2013 - 08:28 PM
Ahhh many thanks! A very usefull table!
#4 Tupers
Tupers
  • 4,156 posts
Posted 06 January 2013 - 08:36 PM
Mini Sport in Australia sell +120 thou pistons and Calver ST in the UK do +100 thou pistons. I can't for the life of me remember what either of those take the bore out to though.
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 06 January 2013 - 08:55 PM
will looking at that chart you gain 16cc for every 20 thou
So i'd guess 1078 and 1094 ???
#6 JackF
JackF
  • 645 posts
  • Local Club: NSMOC
Posted 07 January 2013 - 01:15 PM
conclusion; Its perfectly safe to have my 998 bored to +60thou?
regards
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 07 January 2013 - 03:57 PM
It's not uncommon for IMP pistons to be used in a 998 engine, which as standard are 2.675", and also come in +20 and +40 making a bore of 2.715" which is a total overbore of +0.172"
ps. that chart needs updating to reflect the above...
Attached File  engine_sizes.pdf   10.29K   165 downloads
Edited by Guess-Works.com, 07 January 2013 - 03:59 PM.
#8 Cooperman
  • 23,327 posts
Posted 07 January 2013 - 04:02 PM
I've used +0.080" overbore in a 998 which gives 1060 cc and that is fine.
#9 unburntfuelinthemorning
  • 1,991 posts
Posted 07 May 2019 - 02:57 PM
Were you able to use the standard head gasket?
#10 Cooperman
  • 23,327 posts
Posted 07 May 2019 - 03:32 PM
Yes, it was just OK, but I suspect that a bigger bore would have needed a different gasket.
As someone mentioned, I do recall Imp pistons being used together with a 1098 crank to get a real 'torque-master' engine. A fairly mild cam used to be used, such as the old BMC Special Tuning 731 rally cam, but these days something like an Evo001 would be great.
I do have a spare 998 block and a 998 crank. Maybe one day I'll build something quite radical. I think a 12G940 head and pocketed block would be necessary to get enough mixture in and out.
#11 unburntfuelinthemorning
  • 1,991 posts
Posted 07 May 2019 - 04:47 PM
Thanks, that's useful to know.
If you're going radical with your 998 how about an 8 port head?  Or 16v one?
Whatever happened to the overhead camshaft Howley 8 port head?  I always liked the look of that one.
