but before it was going grrrrrrr before it rev'd if that makes any sense
now it wont start now ive fiddled with the dizzy as i thought it may be that?
so first i need to get it started up then fix that problem
thanks guys :)
Posted 06 January 2013 - 09:10 PM
Posted 06 January 2013 - 09:18 PM
Posted 06 January 2013 - 10:17 PM
what did you do to the dizzy ?
Posted 08 January 2013 - 11:43 PM
Posted 09 January 2013 - 12:27 AM
Posted 13 January 2013 - 09:50 PM
What you turned the dizzy by unclampint it and moving it.....if so you will need to remove rocker cover and remove plugs pop in 4th and pull car forward till both rockers on NO:1 cylinder are rocking (both fully closed) this is the firing stroke....now look at dizy remove cap and put a dot of white paint on block opp rotar are....pop cap back on and turn dizzy till NO:1 lead is opp dot on block.....your mini is now timed retighten clamp and refit plugs and rocker cover (fit new gasket) and start car.......good luck
