What are the minimum and maximum ampage of fuses that go in the fuse box, wondering as i have a mismatch in there at the mo and it could be the bain of my problems!
would check the haynes but its currently gathering moss etc at home and i want to buy them on the way home!
SHOULD READ FUSE!!
min/max fuse ampage
Clubby1275GT
, Apr 05 2006 11:45 AM
1 reply to this topic
Posted 05 April 2006 - 11:45 AM
Posted 05 April 2006 - 03:35 PM
Assuming you have the standard 4 way glass cartridge fuse block you need 1x35A, 2x25A and 1 15A in that order from the top down. The line fuses are all 10s and 15s.
If you have swapped to a blade fuse holder they are rated differently so don't get the same values.
If you have any other form of custom wiring then who knows!
