Hand Made Reamer
Posted 09 January 2013 - 01:44 PM
How would one go about this? Could I use a vice to hold the pin and a small angle grinder with a 115 mm metal cutting disc to cut some flutes about 3 inches along the length from one end, tidy up any burrs and away I go?
Posted 09 January 2013 - 02:31 PM
Graham
Posted 09 January 2013 - 02:34 PM
The bushes are quite soft in comparison to the steel shaft so that's why it's possible to use it. Proper readers are made from tool steel obviously.
Posted 09 January 2013 - 02:52 PM
just a couple of follow up questions
should the channels be just the width of the cutting disc?
How deep should they be?
When you say grinda chamfer, do you mean to in effect taper the very tip of the pin to locate it nicely in the bush when you start the reaming process? (oooh matron)
Posted 09 January 2013 - 03:38 PM
Posted 09 January 2013 - 03:51 PM
Posted 09 January 2013 - 04:54 PM
I must admit I was quite sceptical but people have reported success.
Just width of cutting disc on an angle grinder and yes chamfer is to create a lead in to get it located in the bush to start the reaming process. You are effectively making a reamer. The shaft outside diameter is exactly right to give a running fit in the bush when reamed and the other end of the shaft runs in the needle roller to keep the parallelism, effectively you are line boring the new bush. Some people use fine grinding paste afterwards to lap the new pin in to the reamed bush.
I
Posted 09 January 2013 - 04:57 PM
Posted 09 January 2013 - 05:11 PM
I like the sound of racingenglishcars improvements, the 3 fluted cuts with acute angle on the cutting edge. Bit more sophisticated.
Forgive my ignorance chaps...
I assume you mean angle the grind so that it creates a sharper edge in the direction of cutting rotation?
Also. I had been wondering about ethels point regarding the length of the pin being close. Could a socket on an extension be used to give max reach before the pin runs out of needle bearing to guide it? Or would a socket not pass through the needle bearing?
Thanks for all the advice guys
Edited by jime17, 09 January 2013 - 05:12 PM.
Posted 09 January 2013 - 05:32 PM
*the grease nipple hole is a head start.
particularly note the end view, the cutting face is on a radius to stop it digging in, and there's a clearance angle to stop it binding & grinding with swarf. If you went for three flutes I'd consider doubling it to six on the leading edge. Maybe start with 3 first though, easier to add 'em than take away. A grinding wheel in a drill might also give a better finish. Finer grit & a squarer edge.
Posted 09 January 2013 - 06:05 PM
still much appreciated though.
Posted 09 January 2013 - 06:27 PM
Ethel your precision engineering view is absolutely the right approach to achieve precision and do lots of arms.
by the way the Original 18G588 reamer was not tapered it was a parallel reamer and it also required a collar 18G588A to be inserted in place of the needle arm to ensure bush reamed on same centre line as needle roller.
Posted 09 January 2013 - 06:40 PM
Posted 09 January 2013 - 07:01 PM
Posted 09 January 2013 - 08:18 PM
Excellent. Lucky to find the reamer for £6 well done. Plenty of options now jime17
yeah. Probably the refurb arm is the way to go looking at how complex it seems to do a diy job.
:-S
