GHT 439K
Exterior/Shell:
Fully restored seam welded 1972 tax-exempt mini clubman shell in exceptional condition.
Ford Blue body with Ford Diamond White roof.
Miglia arches.
One off custom 7*13 Image Split Rims running Yoko A048 (M) 175/50/13 tyres
Bulkhead cut and modified to accept gear linkage and space for fuel system
Tubbed rear arches
Fibreglass Boot floor
Fibreglass Bonnet
Fibreglass Boot
Polycarbonate Window Kit
Handbrake moved back 4” and custom setup
Gear change selector hole welded over and replaced with Harry Hockley / quaife setup
Double skinned floor pans
Interior:
Custom dash using revotec gauges.
Safety devices 6-point weld in cage.
Cobra bucket seats with 4-point harness
Fibreglass battery box.
Engine:
2.0 16v Vauxhall redtop engine.
SBD 208 taper throttle body kit
ITG air Filter
Lightly ported and polished head
173bhp 160 ft/lb torque recorded when using twin webber 45’s and no head work. Expected output to be around 200bhp and 180 ft/lb torque.
Gearbox:
F20 gearbox with quaife LSD
Hydraulic clutch conversion using wilwood master cylinder 0.75.
Harry Hockley Gear Linkage
Brakes:
Tarox 6 pots with 240mm discs
Tilton pedal box with brake bias bar. 5/8 master cylinders
Wilwood brake bias valve
KAD rear disc brake setup
Specialist Components Brake quadrants
Internal brake line
Fuelling:
5 gallon alloy tank
SBD supplied high pressure injection pump
SBD supplied regulator
Suspension:
Front avo coilover running 7” 500lb springs
Fully adjustable and rose jointed front top and bottom arms and tie bars.
TDK rear beam
Pro tech alloy offset coilovers running 7” 150lb springs
Exhaust:
Fletcher side exit exhaust system running 2” from custom manifold back through additional silencer.
Other:
Car is in exceptional condition and mechanically requires no work. It will start from one month to the next and has never let me down over the last 8 years running this engine. It was on the road for several years and then I used it for track use so is not MOT’d. It is still road legal and everything works as it should. This car does not get used in the wet and is stored in a dry garage.
V5 is present with correct engine number and CC all registered with the DVLA as it should be.
The engine is extremely strong having had a rebuild 2000 miles ago. It is serviced after every track day.
Suspension and brakes are all as new having done very little work and are checked regularly.
I have a folder full of history and receipts for the car totalling close to £12000. This does not include any labour costs or the original shell purchase.
Only reason for sale is lack of use and I am taking up autograss so need the space.
It is a very sad and reluctant sale as I have been in ownership of this mini for nearly 20 years but I feel it is time to move on.
I am struggling to put a value on this mini as I believe it to be one of the highest spec’d 16V minis out there.
As such I am advertising it for £8500.
Location is Bristol.
Build thread can be found here: http://www.16vminicl...read.php?t=5754
Will update with pictures on request but I am sure most people know of this mini.
Any questions or additional information please call Lee on 07773301954.
Edited by Pooler70, 10 January 2013 - 07:28 PM.
