Oil Leak
7 replies to this topic
#1 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
  • Local Club: open to suggestions
Posted 11 January 2013 - 07:45 PM
So, filled up the mini with oil last weekend for the first time since building it and the diff output seals are leaking. My own fault, I didn't replace them when I built the engine. Anyway, I've got a new set of seals and just wanted to check something before I start.
It's an early 4 synchro box with moulton outputs, looking at exploded diagrams it looks to me like I need to get the drive shafts out the way, then take out the split pin, remove castellated nut, slide off the moulton coupling, then I should be able to get at the seals to remove & replace.
Is it really that simple?
Scott
#2 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 11 January 2013 - 07:52 PM
Of course... I will drain the oil first.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 January 2013 - 07:56 PM
yes mate once you have the split pin out and the castle nut off you have the flange off the output shaft you have access to the seals
#4 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 11 January 2013 - 08:01 PM
Great cheers... I was certain is was, it just seemed too simple! Thought best to ask just in case!
Well that's my Sunday sorted...
#5 mk1leg
mk1leg
  • 9,343 posts
Posted 11 January 2013 - 09:34 PM
the job would be easier if you removed the diff side covers and do the job on a bench........that way you can check the bronze bushes are worn..... :proud:
#6 Cooperman
  • 23,513 posts
Posted 11 January 2013 - 09:48 PM
Yes, you may well find the bronze diff cover bushes are worn and need replacing as well.
#7 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 11 January 2013 - 11:55 PM
Ok cheers! New to this level of detail so appreciate the advice.
#8 scott_65_cooper_s
scott_65_cooper_s
  • 104 posts
Posted 13 January 2013 - 09:21 PM
Thanks once again for your comments. I already had some end case gaskets so took your advice and whipped them off to change the seals. Would never have done it else!
Checked the bronze bushes as recommended and all seams fine. Now all back together, will fill the oil back up tomorrow and check for leaks.
Scott.
