Edited by shabir, 12 January 2013 - 04:00 PM.
Ignition Coils
shabir
, Jan 12 2013 03:58 PM
8 replies to this topic
Posted 12 January 2013 - 03:58 PM
This may have been asked several times so sorry if it has. On minispares website it says the coil gcl 143 is for 1275 factory electronic ignition cars. However minispares in westmidlands advised me to get the gcl 217. However this on there site says its for ballast ignition and 998. But then it's says it's a aftermarket replacement. I'm confused would it be ok to use
Posted 12 January 2013 - 04:55 PM
ITS THE WRONG ONE MATE. IF YOU CAN GET A LUCAS DLB198 OR GCL143
Posted 12 January 2013 - 04:58 PM
When I checked the site I thought yep wrong one. Just confused at the discriptions. Will have to go back next weekend know
Posted 12 January 2013 - 05:38 PM
i got the black one on mine its for electronic igntition seems good gcl143
Posted 12 January 2013 - 06:52 PM
thats the one i was going to get!! this one right http://www.minispare...Back to search.
they recommended this one to me tho, http://www.minispare...Back to search.
currently have this on the car http://www.minispare...|Back to search
Posted 12 January 2013 - 07:01 PM
so the one you have is the unipart one if it works fine
then the black one as on mine should be fine
this coil thing is a pain in the arse
Posted 12 January 2013 - 07:05 PM
only started to think of getting a coil as i wasnt getting a spark, and managed to get a coil to use for testing purposes, then magically i got a spark, but its gone dead again.Yh i have the unipart one, so the one minispares recommended is in fact no good to me then? I did see another thread on here which said to use the black one you have. i asked them a few times if it is the correct one for a metro 1275 engine with factory electronic ignition and he said yes.
Posted 25 January 2013 - 04:49 PM
This exact same thing happened to me. Went to go get a new coil (electronic ignition 1275) and thought I needed GCL143, went into minispares west mids and they suggested GCL217, going with their advice I ended up purchasing GCL217. It struggles to start the engine and will be replacing with GCL 143
Posted 25 January 2013 - 04:55 PM
GCL217 is definitely wrong for a factory electronic ignition. It's a 9v coil for ballast ignition.
As other have said, you need the DLB198 or equivalent.
