Wheels Won't Spin?
21 replies to this topic
#1 its_courts28
its_courts28
  • 644 posts
Posted 12 January 2013 - 08:16 PM
I have fitted new back plates, cylinders & shoes but after struggling to get the drum on it now won't turn. Can anyone help?
#2 samsfern
samsfern
  • 5,243 posts
Posted 12 January 2013 - 08:19 PM
Adjusted up correctly via the square adjuster on the back of the backplate, at the top (iirc) ? Shoes fitted the right way and correctly too? You would have had to have the hub off too to fit a new backplate, was the rear wheel bearing correctly tightened?
#3 03jkirk
03jkirk
  • 465 posts
Posted 12 January 2013 - 08:21 PM
has the handbrake cable been tightend too much so not fully releasing the brake shoes???
Edited by 03jkirk, 12 January 2013 - 08:21 PM.
#4 its_courts28
its_courts28
  • 644 posts
Posted 12 January 2013 - 08:24 PM
Handbrakes slack, all baggy, adjusters right out and the shoes are together
#5 03jkirk
03jkirk
  • 465 posts
Posted 12 January 2013 - 08:30 PM
check that the quadrants on the subframe that these are letting the shoe return properly as the cable may be slack from them to the handbrake but may still be tight between them and the wheel
#6 its_courts28
its_courts28
  • 644 posts
Posted 12 January 2013 - 08:32 PM
Could you explain what the quadrant is please?
#7 03jkirk
03jkirk
  • 465 posts
Posted 12 January 2013 - 08:34 PM
its the pivot on the subframe where the cable turn 90 degrees to go to eeach wheel
#8 its_courts28
its_courts28
  • 644 posts
Posted 12 January 2013 - 08:39 PM
Don't suppose your local to Huddersfield?
#9 03jkirk
03jkirk
  • 465 posts
Posted 12 January 2013 - 08:47 PM
nah sorry mate currently up in perth but jus check that the cable isnt being held up anyway but rust, dirt ect
#10 its_courts28
its_courts28
  • 644 posts
Posted 12 January 2013 - 08:53 PM
Ok no worries and thanks for your help
#11 ibrooks
ibrooks
  • 1,017 posts
Posted 13 January 2013 - 06:12 PM
Why did you struggle to get the drum on? if the shoes are in their proper place and the adjusters are backed off with the handbrake off then the drums should practically drop on.
Did the hub turn freely before the drum went on? this at least would give us an idea where the problem is but if it was hard to get the drum on then I'd suggest that is a strong hint that something is worng with the brakes.
Iain
#12 mini13
mini13
  • 3,811 posts
Posted 13 January 2013 - 06:31 PM
the shoes may just be miss aligned,
slacken off the swuare adjuster all the way and tug on the hand brake cable a few times, that should centralize them in the drum and allow rotation..
if not get the drum off and have a look.
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 13 January 2013 - 07:28 PM
have you got the correct shoes and are they on the right way round ?
Generally if bits don't fit their either on wrong or the wrong part !
#14 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 13 January 2013 - 07:29 PM
wasnt there two topics on here recently about shoes not fitting. they tried another set and they were fine.
#15 its_courts28
its_courts28
  • 644 posts
Posted 13 January 2013 - 08:45 PM
Got the wheels spinning freely now, grinded a bit out the drum and the shoes themselves and they fit:) However, now the brakes don't work properly and it takes a few pumps to get them working so it locks on. They've been bled several times?
