Starting Help ! :(
24 replies to this topic
#16 Jamie_RoverMini35
Jamie_RoverMini35
  • 122 posts
Posted 13 January 2013 - 12:24 AM
hmm but what i was thinking is ive never ever had one from my engine to body in 2 years of owning the car so why would it start playing up now?
#17 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 13 January 2013 - 12:25 AM
Tis why I think its A intermittent fault with the coil, you say its not sparking, but its turning over?
#18 Jamie_RoverMini35
Jamie_RoverMini35
  • 122 posts
Posted 13 January 2013 - 12:28 AM
no its not turning over sometimes, sometimes its fine other times its just the starter clicking even after ive been a drive... but as soon as i jump the car away it goes :(
#19 Noah
Noah
  • 4,136 posts
Posted 13 January 2013 - 12:38 AM
When the starter is just clicking it implies that the battery hasn't got enough juice to turn it over properly, if it wasn't earthed it wouldn't even do that.
You know the starter works as when its jumped it works.
So my things to check would be:
The Coil
Starter Solenoid
#20 Jamie_RoverMini35
Jamie_RoverMini35
  • 122 posts
Posted 13 January 2013 - 12:40 AM
yeah ill check my starter tomorrow :unsure:
#21 Carlos W
Carlos W
  • 10,115 posts
Posted 13 January 2013 - 08:44 AM
The Coil
Starter Solenoid
If the engine is earthing through the heater control cable it won't be able to draw enough power to turn the starter motor!
#22 Jamie_RoverMini35
Jamie_RoverMini35
  • 122 posts
Posted 13 January 2013 - 09:38 AM
yeah but like i was saying why would i start having trouble now and not months ago?
#23 garrymacmini
garrymacmini
  • 168 posts
Posted 13 January 2013 - 09:53 AM
I have a 94 Coop Spi, earth strap from engine steady to body.
#24 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 13 January 2013 - 11:08 AM
The coil will have no effect on the car turning over or no being able to urn over.
It could be the starter, sometimes a faulty start will not work when hot.
An easy way to check is the net time it fails to turn over, whip it out o the car and bench test it. if it works, then its not the starter.
As said previously, check all of your earth leads and make sure your battery terminals are tight.
Hope you get it sorted.
#25 Jamie_RoverMini35
Jamie_RoverMini35
  • 122 posts
Posted 13 January 2013 - 10:18 PM
right folks here an update, so far i have replaced my alternator, my battery earth, my starter motor and my battery, and car was fine today however on my way home i switched everything on to try it when i got home so i could organize a lift to work and when i went to start it after i switched everything off it would even manage to turn over,but what i was thinking is ive fitted halogen headlights recently and i remember having a bit of trouble with power after i fitted them and now the car is used alot more at nights and with more things on. so im thinking my alternator is too small and not giving out enough juice?
