Selling this due to me moving out of my parents and getting a bigger fish tank in the process.
Glass measures 30" high, cabnet measures 26x26" and its 34" corner to corner (at its widest point) cabinet and class is 5ft in height, 6mm thick. Glass was custom made, as was the cabinet.
Cabnet was made and stained by me, using good quality pine, and is reinforced with steel, so much stronger than it need be.
Will come with 2 light units, and tubes (tubes work but its ideal to replace them every 6months and theyre about 9 months old). One light for the plants and one for the fishes colours.
An external fluval 405 filter, which is slightly overkill for this size tank but keeps the water very clear. I have lots of spare media for this.
Tetratec aps400 air pump, which has enough power to power some pretty cool air stones.
300w above gravel heater, and an unknown power undergravel heater.
Im not sure on the capacity of this tank, at a guess id say around 200-250 litres.
The timer switches for the lights and airpumps are also included, as is the socket board built in the cabnet, so only 1 wire is needed to plug this tank in.
(Filter doesnt leak, thats just something i do to prevent accidently unclipping the clips, as i have done before)
Cabnet also has a folding table thing built onto the door, for various uses.
All thatll be needed to set it up is some gravel, bogwood/rocks, plants and livestock, new light tubes too ideally, should cost around £30 for the pair of light tubes.
Ive no idea what this lots worth, it cost me over £1,000 to setup, therefor, im asking for £600 but will accept a sensible offer. I can also deliver reasonable distance for price of fuel, Im located in ashford kent, the tank is also for sale elsewhere. Many thanks.
Edited by samsfern, 13 January 2013 - 07:37 PM.
