Engine Earth ?!?!?
Posted 15 January 2013 - 08:41 PM
Posted 15 January 2013 - 08:55 PM
Get an earth strap fitted as soon as possible.
If the stab bar rubbers are buggered then this could be the earth path at the moment.
If you don't have a good earth strap and you were to re- rubber the stab bar then the earth may be via the throttle or choke cable, then you will have a problem!
Posted 15 January 2013 - 08:58 PM
Have a good look for an engine earth, if there isn't one then fit one. It needs to go to the body, not the subframe. There is a large screw on the bulkhead crossmember under the master cylinders that forms the front wiring earth point and you can earth the engine here. The other end of the cable works well fixed to a transfer gear case screw. But also check the condition of the battery earth, particularly look under the car where the cable is screwed to the boot. It is screwed into a captive nut that is floating inside a cage. The cage fills with road dirt and then the connection becomes poor. You can loosen the screw, spray the cage with loads of penetrating fluid or ideally electrolube and then rattle the captive nut around a lot before you retighten it. That seems to clean it up nicely. If the engine really had no earths and you have to fit one, you should replace your throttle, choke and heater cables (if the heater valve is on the head) as they will have been damaged.
Edited by Dan, 15 January 2013 - 08:59 PM.
Posted 15 January 2013 - 10:11 PM
Posted 16 January 2013 - 01:13 PM
Edited by tiger99, 16 January 2013 - 01:13 PM.
Posted 16 January 2013 - 01:16 PM
Posted 16 January 2013 - 03:19 PM
Edited by The Principal, 16 January 2013 - 07:34 PM.
Posted 16 January 2013 - 06:15 PM
Posted 16 January 2013 - 10:17 PM
Posted 17 January 2013 - 07:01 PM
Posted 17 January 2013 - 07:08 PM
Posted 17 January 2013 - 08:12 PM
Posted 17 January 2013 - 08:52 PM
Glad it's all sorted and safe!
Posted 19 January 2013 - 11:58 PM
Posted 13 February 2013 - 08:03 PM
Note:- Both minis have been recently fully rebuilt, with new electrical components, new wiring, new batteries, good earth cales & earth points etc. Both cars are charging correctly. Still struggling to pin point the source of the problem but running out of ideas?.
