Cable Confirmation Please
Posted 15 January 2013 - 09:03 PM
http://www.theminifo...o-well-thenbam/
The thick brown and purple cable from the alternator wasnt going anywhere. i found a similar size cable bolted to the starter motor. should these be connected?. if they are then it was right infront of me the whole time!! im worried a may have spun the connector out when removing the cable on the alternator. does anyone know if this would bugger it?
thanks for your help, fingers crossed this is it!
Posted 15 January 2013 - 09:16 PM
Hope this fixes it
Posted 15 January 2013 - 09:46 PM
http://www.theminifo...attach_id=68240
Posted 15 January 2013 - 10:23 PM
Posted 15 January 2013 - 10:42 PM
Earlier minis and other cars did not have this.
So in theory you good replace it with a normal cable, but you would be undertaking that risk.
Fusible link cables should be available as all modern vehicles have them.
Are you sure yours has failed? Check the continuity across each nd of this cable.
I thought your original post referred to a missing connector, not a blown fuse link?
Posted 15 January 2013 - 10:53 PM
http://www.amazon.co...1&rh=n:15729691
It might be better to use a large in line fuse instead of nothing.
Posted 15 January 2013 - 11:15 PM
Posted 15 January 2013 - 11:18 PM
I only found some on amazon.com (US)
ok so now the question which one?
Edited by WillRunci, 15 January 2013 - 11:19 PM.
Posted 15 January 2013 - 11:23 PM
Posted 15 January 2013 - 11:29 PM
Posted 15 January 2013 - 11:35 PM
Posted 16 January 2013 - 03:17 AM
