Why Have Arp Head Studs?
7 replies to this topic
#1 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 15 January 2013 - 10:35 PM
As above. Are they torqued down more?
#2 kappa
kappa
  • 1,301 posts
Posted 15 January 2013 - 10:43 PM
I would like to know this aswell
#3 Tupers
Tupers
  • 4,156 posts
Posted 15 January 2013 - 10:52 PM
I know they're made from Cro-Moly a better quality steel than standard ones meaning that they will hold the torque better and be less prone to stretching. I don't know if they're torqued up tighter but it would seem unlikely.
One interesting thing that was pointed out to me by a local engine builder is that the ARP nuts have a considerably smaller footprint than a latter A+ nut. This means that although ARP studs may be able to take more force without stretching they're actually spreading that force through a smaller area which isn't necessarily a good thing.
#4 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 15 January 2013 - 11:01 PM
So they are torqued down to the standard amount?
#5 Cooperman
  • 23,328 posts
Posted 16 January 2013 - 12:14 AM
When you buy the ARP bolt & nut set the torque figures ae given on the data sheet. They quote figures for 'dry' and 'greased' assembly and a small supply of the correct grease is supplied.
For normal road use they are probably over-engineered, but for competition use they are quite simply the very best.
#6 Ethel
  • 26,088 posts
Posted 16 January 2013 - 01:54 AM
Standard A+ bolts are pretty good.
Bolts behave like coil springs under tension, it's their elastic qualities that squeeze the head and block together. If they are too near their upper limit they'll stretch permanently and no longer clamp, but if they are too stiff they won't share the forces as well between them and they will fatigue and fail quicker because the lack of "give" will make the instantaneous forces much higher. A+ bolts are thinner in the middle to make them stretchier. You need to use flanged nuts or washers of equal quality.
#7 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 January 2013 - 07:43 AM
They're also used in engines that are likely to be stripped and rebuilt a lot. Threaded fasteners are prone to stretch (as explained above by Effel). IIRC they are torqued up higher on the A-series kit. Can't remember for definite so don't quote me on that. I know my Minis big end and mains bolts are ARP ones and are torqued higher than standard, but it's not a proper mini engine.
#8 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 January 2013 - 07:46 AM
Nope, use factory torque setting:
