Was used as my daily driver and cant say enough how fun this is to drive
So Heres a FULL spec and pictures with as much info as possible.
Riteo...
Full build diary on here which took about 2 years, Won first place at malvern for custom/classifieds, was its first show, didn't enter it into anything else that year. Also has an awaiting miniworld feature(shoot still to be done)
car weighed in at 580kg's but have added another seat and gubbins so i reckon around the 600-620 mark
1993 british open classic 1600 120bhp at wheels before last mods so i guess its around 140-150bhp now
full mot and tax
unknown mileage but head gasket and cam belt have been done, I did about 6k last year. Engine has been stripped down last year too.
gearbox at 44,000 miles
Look through my build and you'll see almost every-part is brand new or re-furbished. Car would come with previous mots from myself and 18k of receipts from the day i bought the car 2 years ago
Cars kept in a garage so not out in the bad conditions
Engine:
E16SE Nova GTE/GSI engine 1600cc
F13 wide ratio gearbox 374(ithink) 5 speed hydraulic converted
Bill blydenstein full works head (hasnt been RR'd with this on yet)
Fast road Kent cam
Kent Pulley
Bogg bros Inlet, kawasaki carbs and pump with nova sr 1.2 ignition set-up
Pipercross filter
4-1 manifold
Straight through exhaust/cherry bomb silencer no cat
Nippon denso alternator front mounted
Metro radiator with 10" switch operated cooling fan
Oil catch tank
Allspeed powdercoated frame package/shafts/arms etc
Corsa/nova/tigra modified adjustable gear linkage
Nova expansion tank
silicon hoses
Suspension/Brakes:
Front gaz coilovers with 500lbs 7" springs
Rose jointed tie bars/bottom arms
Hi-los and donuts removed
8.4 vented/grooved discs, alloy minisport 4 pot calipers (shaved to fit under wheels)
1.25 inch front spacer
extended track rod ends
Modified tdk rear beam ( to fit exhaust better and higher up into tunnel) with adjustable camber Powdercoated
Billet Handbrake quadrants
Kad rear disc conversion
Protech offset coilovers on rear with 175lbs 8" springs
Beleive its got a quickrack fitted
7x10 mini special splitrim wheels with falken tyres all legal 2 new
Body mods/panels:
New front floor pans
new drivers side rear floorpan section
tubbed rear arches
cage mounting plates
Miglia style bulkhead
allspeed lower bulkhead box
Roof and dash rails cut out
Coilover mounting plates
New passenger door step
New lower scuttle
New under rear light panles
Bins and bench cut out/down
No inner wings
Carbon roof with subaru vent
Carbon look wingmirrors
Carbon wide miglia arches
Carbon cooper s bonnet
Carbon rear bumper and over-riders
Carbon bootlid
Fiberglass passenger door
Fibreglass frontend with a panels
Carbon valance with rear diffuser
Fibreglass bootfloor
Polycarbonate windows with sliders, drivers side is still wind down glass/metal door
Carbon parcel shelf
OMP 6 point cage with removable door bars,dash bar and rear diagonal all padded where needed
Jon Betts harness bar
Interior:
Custon Recaro pro spg seat
Magnum passenger seat
Luke harnesses 4 point black
omp helmet hook
lifeline 2000 plumbed in extinguisher
sound deadenning peeled off floors , completely stripped out
Carbon door cards
Lightweight door furniture
2x handheld extinguishers
Omp seat sidemounts
Custom fibreglass/carbon dash with led switched and leds mounted with an etb digital dash
Snap off steering wheel on a modified steering column with momo boss and wheel
extinguisher and power pull cables located around inside and front scuttle, dissengaged for road use
Powervamp lightweight battery and bracket
modified drivers footwell for tilton floor mounted pedals and wilwood master cylinders(integral) with bias controller mounted by steering wheel
Boot mounted washer bottle
Internal braided fuel lines
Internal power/brake lines
Custom loom with relays and smart fuse box ( flashing led next to a fuse when it blows)
6 Gallon alloy race fabrication baffled fuel tank ( filled up through rear window)
Exterior:
Hid light conversion with led daytime running lights ( not cheap homemade leds) carbon wrapped headlight rims
Clear front indicators
Mark 1 carbon wrapped grille
Lightweight bonnet pins
Smoked rear lenses/carbon wrapped rear light cases
Front tow strap
Led numberplate bolt lights
Custom graphics on car
Aeroblade wipers
Painted in kawasaki 104 green
I hope thats all covered! If youve taken the time to read this and come up with something i really appreciated it and like i said i just want a rough price
Thanks Guys
Ben
Edited by BenH, 17 January 2013 - 09:23 PM.
