What Do People Do On The Underside?
8 replies to this topic
#1 steble
steble
  • 750 posts
  • Local Club: chichester mini club
Posted 18 January 2013 - 09:39 AM
hi guys,
just wondered what peoples favoured method was on the underside of the car to look after it.
I was thinking of giving a good clean up removing all dirt and any surface rust,(which there is very little of on mine) :D
then covering it in a good anti rust paint i.e. hammerite
then covering it in waxoyl
is this good enough or are there better methods????
thanks in advance
steve
:D
#2 mk1steve
mk1steve
  • 12 posts
Posted 18 January 2013 - 09:42 AM
Hi Steve.
on a side note, are you from Chichester? I'm Steve (obviously) and I was born in Chichester.. living in NZ now :)
#3 steble
steble
  • 750 posts
Posted 18 January 2013 - 10:21 AM
Hi Steve.
lol hi steve, yes yes i am
chichester to NZ bit of an awesome change how come your down there?
#4 jaydee
jaydee
  • 8,565 posts
Posted 18 January 2013 - 11:42 AM
I've done it in hammerite, its not the best and there surely better alternatives (stone chip etc..)
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 18 January 2013 - 01:38 PM
Clean and treat any surface corrosion. Etch prime then stone chip. Once hardened topcoat it then you can use a clear waxoyl or similar if you want to see the colour of the paint.
#6 steble
steble
  • 750 posts
Posted 18 January 2013 - 03:25 PM
can you link me the stone chip stuff so i know what i'm looking at never used it before.
does it add much weight? as its going be a superlight fast road/track vtec beast :)
#7 sonikk4
sonikk4
  • 16,080 posts
  • Name: Neil
Posted 18 January 2013 - 06:47 PM
I use Gravitex
http://www.ebay.co.u...=item1e6365c1fb
It all depends on how much you spray on but if you are going for a light weight fast road / track weapon then i would just etch prime and then paint.
I used 4 containers on my son Project Erm
#8 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 18 January 2013 - 07:51 PM
I've just completed some extensive repairs to the floor pans and sills of my Mini (new sills, all 4 floor pan quarters, heal board ends, etc). That left a mix of clean new panels and some areas (like the exhaust tunnel) still covered in WaxOil residue and patches of surface.
I cleaned the whole belly with Mineral Spirits (white spirits) then wiped down with acetone, rotary wire brush to remove any surface rust, the another clean with Spirits/acetone. I then used POR15 Metal Prep (keys the metal), then rinse it off and let dry, then two coats of POR15, then two coats of 3M 08883 Rubberized Undercoat (4 rattle cans). Lots of work but I think it'll be worth the effort.
FYI... I used that solution because its what I had lying around my garage, but have since found it's the current favoured DIY solution for many classic restorations and off-roaders here in the USA... so I guess it should be good for a Mini :)
Cheers,
Colin.
#9 steble
steble
  • 750 posts
Posted 18 January 2013 - 08:35 PM
cheers for the advice guys i will look into some bits and decide as i'm going along :)
i'm starting with the rear fitting a rear beam so thought i may as well do this while i'm at it. and i'll probably make myself a carbon or glass battery box while i'm at it too :)
