Su Leaking
Posted 20 January 2013 - 03:11 PM
Posted 20 January 2013 - 03:23 PM
Posted 20 January 2013 - 03:25 PM
A mate had the same problem fine when the revs were above 1100rpm. But below that it started to mess about.
Think he just changed the float bowl to save any messing around with a spare he had.
What type of carb its it hs, or hiff
Posted 20 January 2013 - 03:26 PM
Posted 20 January 2013 - 03:27 PM
Posted 20 January 2013 - 03:32 PM
Posted 20 January 2013 - 03:34 PM
If you have a spare float bowl and nothing else works , swap it over
Posted 20 January 2013 - 03:44 PM
Posted 21 January 2013 - 11:10 AM
Posted 21 January 2013 - 11:46 AM
Posted 21 January 2013 - 05:36 PM
Posted 21 January 2013 - 07:12 PM
Posted 21 January 2013 - 07:42 PM
Posted 22 January 2013 - 07:13 PM
Posted 22 January 2013 - 08:45 PM
The difference between high and low fuel in the float bowl is difficult to judge when you remove the lid from an HS carb. Remember that a large portion of that fuel (that will appear low) is displaced upward when the float is in the bowl.
If the float is the all plastic type without the metal arm, you may want to adjust the number of fiber washers between the needle valve and the float bowl lid. An extra washer will effectively lower the fuel in the float bowl by quite a bit.
There have also been anecdotal reports of new float valves not sealing properly. (Before going further, if you have installed Grose Jets with the ball bearings... remove them and fit Viton tipped traditional float valves before spending any more time troubleshooting). If you have a float valve with metal on metal sealing surfaces, you can try lapping the two contacting surfaces together. People on this board have used toothpaste for this purpose in the past. If that is not something you want to try, buy the Viton tipped float valve I mentioned earlier. The Vition tipped valves seal very will for long periods of time when other valves have problems.
