Unipart Oil Filter/fram Filter Alternatives
11 replies to this topic
#1 MiniMoe2008
MiniMoe2008
  • 166 posts
  • Local Club: None Around Here
Posted 20 January 2013 - 08:28 PM
Hey Everyone,
Just trying to figure out of there is any other filters out there instead of Fram PH966B or Unipart GFE 443? I preffer to use K&N or Bosh as I have used these for years and have never had problems. Thanks
Eric
#2 mattbeddow
mattbeddow
  • 337 posts
Posted 20 January 2013 - 08:33 PM
Ive not had any problems with the unipart filters on my mini. I think they used to make the OEM oil filters
#3 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 20 January 2013 - 08:42 PM
Unipart were the OEM suppliers - Unipart was in fact founded by British Leyland
#4 Big_Adam
Big_Adam
  • 7,435 posts
Posted 20 January 2013 - 08:45 PM
Never had a problem with either Fram or Unipart. Then again, as long as it fits, not too fussed on brand. It's getting changed in 6months.
#5 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 20 January 2013 - 08:47 PM
there all good in my books
#6 MiniMoe2008
MiniMoe2008
  • 166 posts
Posted 20 January 2013 - 09:04 PM
Ive had my bad experience with fram. Specially at the seam I have found that the filter was only pinched shut with a piece of metal. There are gaps where particles can go thru. As for Unipart, not personally.
Edited by MiniMoe2008, 20 January 2013 - 09:05 PM.
#7 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 21 January 2013 - 09:45 AM
http://www.autoparto...art/gfe443.html
This website gives alternative filters including a Bosch 0451102001
#8 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2013 - 10:42 AM
Champion C103
#9 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 21 January 2013 - 02:27 PM
Well, since here in the States we need to improvise a bit with part substitutions I found this list of filters that fit the Mini from a Texas Mini club website. Some of the filters are of the taller type that are little harder to fit.
  • AC DELCO 93156323
  • AC DELCO 25011520 (PF 53)
  • AMSOIL SDF-57
  • BECK/ARNLEY 0418988
  • BOSCH 72150
  • FRAM PH966B
  • FRAM PH2870A
  • FRAM PH3614
  • K&N HP1002
  • MANN 056 115 561G
  • NAPA 1374
  • PUROLATOR L10028
  • PUROLATOR L10241 Metro 1.3L
  • UNIPART GFE148
  • WIX WL7142
  • Mobil M1 102
#10 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2013 - 02:48 PM
I've heard the purolator being particularly good.
There should be also a very good filter from knecht but then who knows the code..
#11 MiniMoe2008
MiniMoe2008
  • 166 posts
Posted 21 January 2013 - 06:56 PM
  • AC DELCO 93156323
  • AMSOIL SDF-57
  • BOSCH 72150
  • FRAM PH966B
  • FRAM PH2870A
  • FRAM PH3614
  • K&N HP1002
  • MANN 056 115 561G
  • NAPA 1374
  • PUROLATOR L10028
  • UNIPART GFE148
  • WIX WL7142
  • Mobil M1 102
Super Mini Mad, Thank You!!! This is exactly what i was looking for. I'll be moving back stateside in a few years but you never know with the military. I'll be buying the Bosh or K&N on Thanks.
#12 CityCharlie
CityCharlie
  • 56 posts
Posted 21 January 2013 - 07:55 PM
A few racers I know refuse to use Fram due to the casings letting go with obvious consequences. I have never had an issue with this myself.
Mann tend to make half decent filters and are generally available for half decent money from GSF, coming with the necessary 1 way valve (some argue that this is not required in the Mini due to the oil filter's orientation (I.E it is not prone to draining itself) in addition to a bypass valve should the filter ever get blocked (I.E it will shove unfiltered oil around the engine should the filter ever block up for whatever reason (and thus without the valve give very little oil pressure)). I believe Volvo amongst others (Peugeot did for a small amount of time) use Mann filters as OE filters.
