Can You Get 14" Alloys On A Mini
Posted 21 January 2013 - 09:22 AM
Posted 21 January 2013 - 09:28 AM
Just what Ive heard from people from a man who owns 12 minis that he rebuild from scratch himself (all mint condition). I got told either stick with my 12s or go to 10s if you want to bit more fun when driving
Posted 21 January 2013 - 09:29 AM
Posted 21 January 2013 - 09:45 AM
I don't know if can get a 14" tyre with the same rolling circumference as an equivalent 13" Mini tyre. I'd imagine not as it would have to super low profile in which case you'd almost certainly have to tub the rear arches and cut more out of the wings for clearance.
Roofless's Car does looks quite smart on 14s and I have no doubt they can be made to fit and have at least safe handling/road holding but if you're looking for performance fit some 10s.
Posted 21 January 2013 - 09:57 AM
Posted 21 January 2013 - 10:26 AM
mine is for all intense and purpose a sportspack body without a roof, and needed no further modifications to run the 14's.
Posted 21 January 2013 - 10:27 AM
Posted 21 January 2013 - 10:31 AM
yes....... with 195 45 14 tyres the rolling radius is only 6mm larger than 175 50 13 tyres ......the cabriolet has been on 14's for nearly 12 years
But... But.... I thought 14's on a mini is pretty much tr car version of the anti-Christ??
That looks good! So confused..
Posted 21 January 2013 - 10:35 AM
Posted 21 January 2013 - 12:44 PM
Posted 21 January 2013 - 01:48 PM
Ive seen the 13" wheels alot and they look good but i want 14s as i can get bigger breaks and slightly better handling is this possible?
As others have said 14" wheels are likely to make handling worse as opposed to better, also what sort of highly tuned monster are you running in order to need bigger brakes? If you've got some sort of insane modern engine conversion throwing out 100+ bhp, then I can understand that you might need to upgrade, but otherwise the standard 8.4" disc set up, (or 7.5" cooper discs) tend to be perfectly adequate for most moderately tuned classic minis.
Posted 21 January 2013 - 02:01 PM
Posted 21 January 2013 - 02:14 PM
However, the stopping and road-holding in the wet would be appreciably worse and the road-holding on bumpy roads would also be poor as the Mini suspension needs a decent sidewall depth to help the suspension due to the short suspension travel of the standard Mini suspension.
But, if you want to race or hill-climb the car and will be fitting very sticky 14" slicks for the dry that's another matter entirely and on a dry and smooth race track would work really well - illegal on the roads, of course.
Posted 21 January 2013 - 02:29 PM
http://www.facebook.com/home.php#!/photo.php?fbid=414627831929330&set=a.414627685262678.95670.171397246252391&type=3&theater
http://www.facebook.com/media/set/?set=a.414627685262678.95670.171397246252391&type=3#!/photo.php?fbid=414628741929239&set=a.414627685262678.95670.171397246252391&type=3&theater
http://www.facebook.com/media/set/?set=a.414627685262678.95670.171397246252391&type=3#!/photo.php?fbid=414628758595904&set=a.414627685262678.95670.171397246252391&type=3&theater
Posted 21 January 2013 - 02:32 PM
Even then ou can sill get KAD 6 pot brakes under 13's. You can't need any more braking force than that!
Very true, at the end of the day we're talking about stopping a car that weighs under 650kg here. Regardless of how powerful your car is, once you have enough braking power to lock the wheels up, surely it's not going to slow down any faster until you increase/improve the rubber that's in contact with the road surface?
Edited by AVV IT, 21 January 2013 - 02:32 PM.
