Head Alignment Stud
Posted 21 January 2013 - 10:14 AM
Thanks Peter
Posted 21 January 2013 - 10:41 AM
Posted 21 January 2013 - 10:43 AM
Posted 21 January 2013 - 10:48 AM
Posted 21 January 2013 - 11:44 AM
Posted 21 January 2013 - 11:45 AM
in fact if i had any stud missing i wouldnt fit the head!
Posted 21 January 2013 - 12:12 PM
I think he may be confusing bolts and studs.you are missing a stud? if you are missing the aligning stud it may nor go on square. i wouldnt fit the head then.
OP- do you have any threaded holes in the top of the block which don't have anything in?
Posted 21 January 2013 - 12:16 PM
If the front middle hole in the Mini is tighter than the others (can't say that I have ever noticed, and I have had heads off more times than I care to remember), it would only locate the head at one point, and it could rotate slightly, depending on the clearance in the outer holes. My general impression is that all of the studs are sufficiently close fitting that there is not a problem.
Posted 21 January 2013 - 12:18 PM
Posted 21 January 2013 - 02:02 PM
Posted 21 January 2013 - 02:15 PM
It is. It positions it roughly, if it wasn't there the head
Would be able to move sideways, putting the chambers off centre to the bore. Can't be good:P
Posted 21 January 2013 - 04:29 PM
I suspect that most people who successfully overhaul and rebuild Mini engines are blissfully unaware of the centre hole being tighter. If it is doing its job you don't have to know.
Posted 21 January 2013 - 05:40 PM
