Centre Exit Exhaust Fitting.
13 replies to this topic
#1 sidewalk_1995
sidewalk_1995
  • 27 posts
Posted 21 January 2013 - 01:28 PM
I have a 1275 spi and want to fit a centre exit exhaust.
Is there a guide somewhere on how to fit these? I am only fitting from the CAT back and want to know what clamps etc I'll need to buy.
This is the exhaust i want to get
http://sportexexhaus...108/product/255
has anyone else bought this? Was it a fairly standard swap?
#2 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 21 January 2013 - 01:30 PM
I always thought they had a U shape clamp that goes around the pipe, and bolts onto the rear subframe.
If I were you i'd stick to a single centre exit, but that looks like a similar idea, just the bolts are in a different place.
Edited by Noah, 21 January 2013 - 01:31 PM.
#3 sidewalk_1995
sidewalk_1995
  • 27 posts
Posted 21 January 2013 - 01:38 PM
Looking around other forums, the two bits sticking off the tail pipes, just require holes drilled in the subframe.
My question is the fittings further down.
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 21 January 2013 - 01:58 PM
should be 2 bolts which correspond to the centre section in the picture, if your car doesnt have this you can get a link pipe and use 2 exhaust clamps.
#5 freshairmini
freshairmini
  • 1,718 posts
Posted 21 January 2013 - 02:54 PM
On mine there were two holes already in the middle of the subframe, I used those. Not the same exhaust as mine but the same mounting.
#6 sidewalk_1995
sidewalk_1995
  • 27 posts
Posted 21 January 2013 - 04:40 PM
Cool.
Thanks, i have just ordered it and some bobbins as well.
I think ill have to drill my hole but that's not a massive issue.
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 January 2013 - 04:43 PM
if you buy a cat back system off someone like minispares they will also be able to supply a fitting kit
Edited by Bungle, 21 January 2013 - 04:43 PM.
#8 jpw1275
jpw1275
  • 2,803 posts
Posted 21 January 2013 - 07:21 PM
i have a centre exhaust fitted and im sure its only fixed on the rear subframe and no where else... but mine isnt an spi so may be different
cheers
james
#9 freshairmini
freshairmini
  • 1,718 posts
Posted 22 January 2013 - 12:21 PM
cheers
james
Mine it fitted using the same bobbin system at the centre rear of the subframe, which is the same mounting used for the OEM exhaust.
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 January 2013 - 01:23 PM
Do you not use the square block mounting at the centre front of the rear subframe as well as the bobbins at the rear? long way between the joint of the LCB to the rear bobbins if not ??
#11 finch661
finch661
  • 2,340 posts
Posted 22 January 2013 - 01:34 PM
little bit off topic, but are spotex exhausts any good? saw in comparison to maniflow or the rc40?
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 January 2013 - 02:32 PM
Not sure what development work goes into sportex exhausts ? Cost wise I'd go for a RC40 which is a well proven and developed product. Took of a RC40 on mine (2 box really quiet) and replaced it with a single box maniflow and quality on the Maniflow is up there with the best but at a much higher cost.
#13 finch661
finch661
  • 2,340 posts
Posted 22 January 2013 - 02:37 PM
that the same setup i was planning, how much louder is it?
cheers (sorry for hi-jacking)
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 January 2013 - 02:49 PM
Twinbox RC40 really quite and single box Maniflow now has that burble/bark to it and sounds nice, recommend one
Check Video on youtube
not mine buts sounds the same
Edited by KernowCooper, 22 January 2013 - 02:52 PM.
