Hi,
Should be collecting a 3 clock set up that includes a rev counter this week, should the set of clocks swap straight over, and what do I need to wire up the rev counter. Is there a new wiring loom / plug I need?
I have also bought the 3 clock bracket that bolts to the dash bottom panel to replace the existing 2 clock.
How To Install 3 Clock Inc Rev Counter To Clubman 1098 With 2 Clocks.
Patriot
, Jan 21 2013 10:54 PM
4 replies to this topic
Posted 21 January 2013 - 10:54 PM
Posted 21 January 2013 - 11:01 PM
Depends how old the wiring loom is, give a look, there should be a white wire laying there unused, thats for the rev counter.
If theres no white wire, feed the rev counter from negative side of the coil.
Posted 21 January 2013 - 11:05 PM
Wiring loom 1977!!!!!!
Thanks I will check
Thanks I will check
Posted 21 January 2013 - 11:22 PM
there should be a bullet black?white tracer and green/orange spade neatly tucked away. also if your mini have been converted to electronic ignition clocks need to be rvc type not rvi as rev counter wont work. this is normally located on clock faces, later nippon seiki are rvc
hope this helps
hope this helps
Posted 22 January 2013 - 06:30 AM
