Which Head For 1098 Engine Tuning...12G295
3 replies to this topic
#1 Patriot
Patriot
  • 125 posts
Posted 21 January 2013 - 10:59 PM
Hi,
I'm trying to find a 12g295 head to fit to my 1098 engine for a little power increase.
Can't seem to find one, what other head is similar, already got a 12g940 head spare, but it seems it is not a straight swap without block work, like the 12g295.
Thanks,
Mark
#2 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2013 - 11:05 PM
As long as your staying standard with camshaft lift, you can measure and see if you can fit the 940 without pocketing.
99% you can get away by recessing the exhaust valves, if you have a good search you'll find an how to guide somewhere (Calver?).
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 21 January 2013 - 11:06 PM
you can use a 940 head with no mods unless you use a high lift cam in which case you will have to pocket the block, the 295 will give a good power increase but you must skim the head by 80 thou to bring the compression ratio back up, my last 1098 had a 295 head, kent 266 cam, kent vs2 springs and twin carbs, it was rolling roaded at 75bhp and used to run rings around 1275's
Edited by oltonlad, 21 January 2013 - 11:08 PM.
#4 BritishRacingGreen
BritishRacingGreen
  • 433 posts
Posted 21 January 2013 - 11:18 PM
the 12G202 is also rather good (though not as good as the 295, but could always get some mods done?) and are more available i believe?
