Gearbox Noise
oltonlad
, Jan 23 2013 05:52 PM
7 replies to this topic
Posted 23 January 2013 - 05:52 PM
hi all, the mini that i've just bought has got a bit of a noisy gearbox in 1st,2nd and 3rd......its ok in 4th gear, i know its a bearing noise but is it more likely to be the main double roller or the input bearing by the transfer gear?
the gearbox changes gear smoothly and doesen't crunch or jump out of gear at all.
the noise is only just about noticable but i can hear it, i had a mini ritz before with this problem but it was much much louder and lasted for ages until i finally replaced the engine with a 1275.
Posted 23 January 2013 - 06:29 PM
You could try sending guessworks a PM, he'll be able to give you an answer
Posted 23 January 2013 - 06:40 PM
Is it not just the normal Mini gearbox whine you get anyway?
Posted 23 January 2013 - 06:47 PM
nah............its definetely bearing noise......its a deep tone.........not the high-ish pitch tone from the gear whine
Posted 23 January 2013 - 07:06 PM
Impossible to say really unless John (Guessworks) knows that one has a much higher failure rate than the other.....
Posted 23 January 2013 - 07:15 PM
yeah...........its gotta come out anyway so i guess i'll find out when its out, it may give me an excuse to put a straight cut gearset in.......
Posted 23 January 2013 - 07:22 PM
In the lower gears the power goes through the laygear - so it may well be the layshaft and/or needle rollers. In 4th gear it's straight through drive - so no load on the laygear...
Posted 23 January 2013 - 07:26 PM
Best answer you ever gave, and not even the slightest bit patronising, i'm impressed!!!
