I'm Such A ****
77 replies to this topic
#1 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 23 January 2013 - 10:41 PM
Just driving home from work and went to see a mate on a carpark to show him the mini...
It was covered in snow and forgot that there are these diamond things made of brick about 4 inch high, they usually have trees in but this one didnt and I completely forgot it was there...
I drove into it and my left wheel has now been jerked out more to the left or the right wheel has been notched out to the right but I am pretty sure its the left wheel...
Making steering to the left dead easy but to the right really tough..
I'm quite worried because I am skint after getting it through the MOT and owe money to people so dont want to fork out loads to fix it :cry:
Track rod end?
Tie rod bent?
Steering rack?
Subframe rear mounts moved in/back?
I know I cant diagnose it off the forum but looking for immediate thoughts and costs too please - I found this thread helpful http://www.theminifo...ng-to-the-left/
Really pissed off at myself for doing it..
Cheers all
#2 Hegnirst
Hegnirst
  • 3,496 posts
Posted 23 January 2013 - 10:45 PM
Track rod end?
Tie rod bent?
Steering rack?
Cheers all
duuuuuuuuude not cool, glad your ok though :D
track rod ends and tie rod's are the least of your worries, as long as its not something like a steering rack it will be relatively cheap to fix :) but i would of thought tie rods, track rods, cv joints etc and the like that are actually connects to the wheel mechanism :P
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
one of the above yeah
your going to have to get under it tomorrow and have a look
#4 jaydee
jaydee
  • 8,565 posts
Posted 23 January 2013 - 10:47 PM
Its probably just a bent tie rod. Cross fingers and inspect it.
If the subframe have moved, it would have bent the floor/heelboard panel.
#5 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 23 January 2013 - 10:48 PM
get your tracking redone if its something they dont notice and its still feeling weird thats when you worry about subframes and steering racks
#6 conlad
conlad
  • 2,054 posts
Posted 23 January 2013 - 10:49 PM
Was only doing 5 - 10mph :ohno: >_<
I hope it aint steering rack though...
I can fix the simple stuff on the drive though so thats cool
No creaks or snaps so guessing subframe is OK..
EDIT: is it OK to drive like it is for a short time?
Edited by conlad, 23 January 2013 - 10:50 PM.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 January 2013 - 10:59 PM
NO!
#8 conlad
conlad
  • 2,054 posts
Posted 23 January 2013 - 11:01 PM
NO!
Cheers haha =]
#9 icklemini
icklemini
  • 2,982 posts
Posted 23 January 2013 - 11:02 PM
check the front mountings of the tie rod... the 'ears' bend back...
#10 conlad
conlad
  • 2,054 posts
Posted 23 January 2013 - 11:03 PM
Would these be your most 'probable' guess at what has happened??
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 January 2013 - 11:05 PM
Get us a couple of pictures of the underside.
#12 conlad
conlad
  • 2,054 posts
Posted 23 January 2013 - 11:07 PM
Will do tomorrow... :)
So which end on here - http://www.minispare...|Back to search - might of bent?
#13 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 23 January 2013 - 11:16 PM
It really depends on how you hit it. No point guessing until you have a look or stick some pretty colour pictures on here8) otherwise you are just pissing into the wind.. :P
Edited by Artful Dodger, 23 January 2013 - 11:17 PM.
#14 conlad
conlad
  • 2,054 posts
Posted 23 January 2013 - 11:19 PM
Lmao true mate, will get pics up tomorrow of everything
#15 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 23 January 2013 - 11:37 PM
Stick it on stands and have a look.
You can't tell what damage has been done, for your sake I hope its only a Tie-Rod or Track Rod end.
You can DIY the tracking so its near enough, and then get it set up properly. String, A Tape Measure and some chalk.
