Choose either the twin box RC40 or the Maniflow equivalent, both are quality, well developed systems and there really is little but personal preference between them.
http://www.minispare...|Back to searchhttp://www.somerford...oducts_id=14154If you are still using the standard cast manifold though, and you are planning to replace it with one of the aftermarket manifolds suggested here (Maniflow Freeflow etc), then you will also need to replace the inlet as well, because the standard inlet is joined to the standard exhaust manifold. At which point you may as well just buy a complete stage 1 kit, as the only components you wont have bought, will be the high flow air filter and correct carb needle.
Your other option is to replace the standard manifold/inlet with another standard item (used ones are cheap and readily available due to the popularity of aftermarket manifolds and stage 1 kits.) and then connect it to your performance exhaust of choice using a magic pipe.
Edited by AVV IT, 26 January 2013 - 07:24 PM.
