1.3 Roller Rollers
Posted 27 January 2013 - 07:04 PM
are they any good,is there any real difference
Posted 27 January 2013 - 07:08 PM
Posted 27 January 2013 - 07:22 PM
Posted 27 January 2013 - 07:30 PM
Posted 27 January 2013 - 07:45 PM
Posted 27 January 2013 - 08:32 PM
Posted 27 January 2013 - 09:17 PM
However, if you are going to pay 200 odd quid for roller rockers, your'e better off continuing to save and get the head modified, or, cheaper still, fit an unmodified 1275 cylinder head, preferably MG metro (with suitable mods to allow it to fit)
Incidently the standard sintered rockers do not give anything like the ratio that is quoted, atleast not the ones i measured. They weren't even making 1.21 ratio at full lift, (i didn't measure through the cycle so i can't comment on that). So even a 1.3 ratio rocker is going to give you a fair chunk of extra lift.
If you do fit higher ratio rockers you should not use stronger valve springs, and the valve clearances need to be opened by the same proportion as the rocker ratio increase. Rapid wear may result otherwise.
Posted 28 January 2013 - 06:12 PM
Money wasted in my opinion lots of places to spend it on before roller rockers come on the list
Posted 28 January 2013 - 09:15 PM
1.3 rollers are about 1.27 and, if fitted properly, they'll make a difference.
Wasted money if they come on a 'vintage' engine, good idea if its a brand new build.
Posted 29 January 2013 - 09:08 AM
Posted 29 January 2013 - 05:54 PM
Old style pressed steel rockers have a better lift ratio than the sintered type, and can also be rebushed to prolong their life.
Yes, and they are lighter too. If you want to use the old pressed rockers at high revs the trick is to run a line of weld across the top face where the two sides are pressed together. That stiffens them without much increase in weight. Grind the weld back and they are very strong and still extremely light.
Posted 29 January 2013 - 09:28 PM
I've not used 1.3 rollers....but if I had money burning a whole in my pocket, I'd buy a case of Guinness and a set of 1.3 rollers
Edited by Spitz, 29 January 2013 - 09:29 PM.
