Additional Fusebox?
18 replies to this topic
#16 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 29 January 2013 - 11:15 AM
you need to work out the amperage of all the extras you want to run and then find the next cable size rating up
#17 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 January 2013 - 11:29 AM
Ok, thanks for that. Assume then that there are different rated cables then. I guess all devices have what their maximum load is. Thanks for advice all.
I like the look of these http://www.polevolt....info_5025B.html
Edited by maccers, 29 January 2013 - 11:34 AM.
#18 lrostoke
lrostoke
  • 6,923 posts
Posted 29 January 2013 - 11:31 AM
http://www.vehicle-w...le/thinwall.php
Used these guys for wiring switches extra, been ok so far.
#19 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 January 2013 - 09:30 PM
I've order two 1 in and 6 out fuse boxes. I intend to use one for switched live to run fuel pump, ECU, injectors, coil pack. Emerald suggest running all those off of seperate switched feed. so I can run 4 relays off 4 of the 6 outputs, or run the one relay before the main live feed into the fuse box - whats best and wont cook things?
