Any one used these engines?
Had any problems?
What kind of power is your producing?
Thanks in advance,
James
Edited by Noris8322, 27 January 2013 - 11:41 PM.
Posted 27 January 2013 - 11:14 PM
Posted 27 January 2013 - 11:48 PM
Posted 28 January 2013 - 12:09 AM
Posted 28 January 2013 - 12:46 AM
Posted 28 January 2013 - 07:37 PM
Posted 28 January 2013 - 09:20 PM
Posted 28 January 2013 - 09:58 PM
What did they ask for what spec?
Posted 28 January 2013 - 11:24 PM
Posted 28 January 2013 - 11:34 PM
Posted 29 January 2013 - 07:36 PM
How much?
Posted 29 January 2013 - 07:43 PM
With these volume produced reconditioned engines one might wonder how carefully and thoroughly they are put together. The quality of a re-built engine is in the way it is asssembled as much as what new parts to what specification they are. For example, do they properly 'gap' all the piston rings? Is the cam timing set accurately using offset keys when required? Do the pistons come right to the block deck level at TDC? Are quality duplex timing chain and quality timing chain sprockets used? What quality pistons are used? Are new big-end bolts & nuts used?
As with all things, you usually get what you are paid for.
Edited by Noris8322, 29 January 2013 - 07:44 PM.
Posted 29 January 2013 - 08:14 PM
How much?
£1681 without gearbox
£2559 with gearbox
Posted 29 January 2013 - 08:19 PM
Posted 29 January 2013 - 08:34 PM
