Turbo Pistons? Confirm Numbers Please!
8 replies to this topic
#1 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 28 January 2013 - 04:00 PM
Right, I bought a 1275 engine, with no head, the other day (only for N/A use at the moment), and upon inspection it appears to have a set of standard metro turbo pistons fitted, at least from what I can find from the limited info on the internet (could only find a link to a question on turbo minis forum). If anyone knows for sure what pistons these are and/or where they originally came from, then could they please let me know.
Three of them have the number 20831 L2, and one of them is 20831 L14, all with a B stamped in the dish and 'std' on the edge (I assume for standard size, i.e. not overbore).
Any info much appreciated.
The Otter
Edited by The Otter, 28 January 2013 - 04:31 PM.
#2 kappa
kappa
  • 1,301 posts
Posted 28 January 2013 - 04:28 PM
I will have a look at mine tonight and let you know mate
#3 eden7842
eden7842
  • 907 posts
Posted 29 January 2013 - 10:36 PM
I think there the lookalikes, if the have 3 comp rings and 1 oil then im right
#4 Globule
Globule
  • 1,134 posts
Posted 30 January 2013 - 08:21 AM
Has the engine got an engine number? All the metro turbo pistons I have are 20831 L* with an A or B stamped into the crown.
#5 kappa
kappa
  • 1,301 posts
Posted 30 January 2013 - 10:32 AM
Hi mate the ones I have are all 20831 L13 and A stamped in the crown
#6 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 30 January 2013 - 06:03 PM
Measure the dish volume, if it's 12cc then they're the stock Turbo pistons.
#7 The Otter
The Otter
  • 620 posts
Posted 30 January 2013 - 07:10 PM
Cheers guys, they certainly sound like they're turbo pistons then. I'm away from the engine at the moment and won't be able to do anything with it for a couple of months now, so I'll have to measure the dish volume when I get back to it to make sure.
The engine number in guessworks brings it out to be from an 88 Metro, but just in case it once was a turbo engine, are there any other things noticeably different from the pistons down? Should they have a stronger crank/gearbox or anything?
Also, would these turbo pistons be worth much? I'm not planning on selling them, but if they were super rare or something it'd be nice to know!
The Otter
#8 eden7842
eden7842
  • 907 posts
Posted 30 January 2013 - 11:13 PM
If guessworks thing says 88 metro (not turbo) then there defantly the lookalikes,
Only difference is the turbos have a slightly thicker skirt and 1 less ring.
Not sure how good they are as I dont belive anyone has tested them
#9 Globule
Globule
  • 1,134 posts
Posted 31 January 2013 - 06:02 AM
It may also have a 6851 cranks rather than a 6232 (I believe this was on earlier metro turbo's only, but someone may have transplanted the crank and pistons together).
They aren't worth a great deal really.
