Fuse Box Guide?
Posted 28 January 2013 - 10:42 PM
thanks
Posted 28 January 2013 - 10:43 PM
What year is the car? Is it MPI, SPI or Carb?
Posted 28 January 2013 - 10:44 PM
Its a 1992 mini city and carb, I mean the whole box itselfHow to change a fuse? Pull it out, insert new fuse.
Posted 28 January 2013 - 10:47 PM
Pull them off, two screws hold it on, new one on, re-attatch cables install fuses done.
Posted 28 January 2013 - 10:48 PM
I will give it a go once i order a new boxTake a picture so you know where the cables and fuses go.
Posted 28 January 2013 - 10:54 PM
Standard 4 fuse box mounted on the bulkhead: -
1 1-2 35amp Brake Lights, Reverse Lights, Direction Indicators & Rear Screen Demister.
2 3-4 25amp Horn, Headlamp Flasher, Brake Failure Circuit & Radio Memory.
3 5-6 25amp Heater Blower Motor, Windscreen Wipers, Washer Motor & Instruments.
4 7-8 15amp Side & Tail Lights & Panel Lights.
1-2 These circuits only operate with the ignition switch at position "II".
5-6 These circuits only operate with the ignition switch at position "I" or "II".
The 4 Fuse box wiring colours should be from top to bottom: -
White - Green
Brown - Purple
Light Green/White - Light Green/Orange
Red - Red/Green
Inline fuses situated behind the air-filter on the bulkhead
* 15amp - Purple/Orange Wire Hazard Warning & Interior Lamps
* 15amp - Brown/Orange Wire Dim-Dip Lighting
* 10amp - Blue/Orange Wire Rear Fog Guard Lamps
* 15amp - Blue/Red Wire Auxiliary Cooling Fan (where fitted)
Earth are the Black wires
Sidelights are Red/Red with Green
Headlights are thick Blue with Red
Main Beam thick Blue with White
Green/blue is for the temperature sender
White/brown is for the oil pressure switch
Posted 28 January 2013 - 11:51 PM
Ignore Noah, he has an attitude problem.
Posted 28 January 2013 - 11:53 PM
Harsh.....
You called my Bakewell a mess.
Posted 29 January 2013 - 11:49 PM
Very much appreciated, thanks!This may help you out
White - Green
Brown - Purple
Red - Red/Green
