Got a leak have just replaced rear opening seals. Water is getting in somewhere it lands on the parcel shelf, quite a bit, have looked at all the seals last night and cant see where its coming from does anybody have any ideas. I also get a tiny bit in both rear bins
Rear Water Leak
pierres
, Jan 29 2013 10:34 AM
5 replies to this topic
Posted 29 January 2013 - 10:34 AM
Posted 29 January 2013 - 12:02 PM
rear window and side windows
Posted 29 January 2013 - 05:11 PM
Posted 29 January 2013 - 06:06 PM
Your best bet is to sit in the car whilst someone gently hoses the areas where you suspect water may be getting in. This should show up your issue.
Most likely rear window, if it lands on the shelf. You really need to dry it off, and get an assistant to direct a hose over various areas around the window while you observe for fresh leakage. It is possible that the metalwork under the rubber seal is corroded and will need welding, but it may have not got that bad yet. Once you are sure that the leak is in the window seal, the window needs to come out for examination, and if there are early signs of rust deal with them properly before putting it back in with a new rubber.
Posted 30 January 2013 - 08:15 AM
Thanks for the advice will do this at the weekend
