What Should I Replace In My Gearbox On My 1275 Gt ?
Posted 29 January 2013 - 10:59 AM
Before I removed the engine the mg metro gearbox seamed fine, no crunches, selection problems or anything obvious to worry about. (Pic attached)
Here is my question without spending unnessesary money what would folks advise to replace as a matter of course? different people suggest different parts to be replaced........or should I just put it back as is and hope for the best?
Darren
Posted 29 January 2013 - 11:02 AM
Posted 29 January 2013 - 11:09 AM
Posted 29 January 2013 - 11:14 AM
Posted 29 January 2013 - 11:32 AM
Posted 29 January 2013 - 11:42 AM
Lol..............this is my problem...........the more people I ask..........the more different opinions I get.......I want to do the minimum required for a safe bet?............this is an occasional use road car that does not get raced..........lets face it..........it's not difficult to drop the box out if I suspect problems when it's running.
Well you did ask for opinions on what to replace, rather than waiting until we can actually see whats inside the box.......
Posted 29 January 2013 - 12:53 PM
Posted 29 January 2013 - 12:57 PM
Posted 29 January 2013 - 01:16 PM
Just have a word with guessworks on here. He'll strip, clean check and rebuild and replace worn parts. It all which is all you really need for a road car.
+1 for guessworks
I got my 1275GT rebuild kit from him along with a new gearbox & dif case.
Posted 29 January 2013 - 01:19 PM
If you're on a budget and want to go for the minimum, you're fine as is, if you want to go the extra mile, get a gearbox recon kit and treat it to new bearings and baulk rings. Unless the gears show obvious and heavy signs of wear and/or you want to change to a different ratio, they should be fine to reuse.
Edited by Gulfclubby, 29 January 2013 - 01:21 PM.
Posted 29 January 2013 - 06:44 PM
