Basically I am re-building my turbo engine, I have put new big end and main bearings in.
Now I am going to torque it all down, by referring to the Haynes manual.
The crankshaft main nuts states 40lb.ft torque
The conrod main nuts states 35lb.ft torque.
Basically I go to torque it all down and once near the actual torque, I just check the crank turns over by hand, it does but very hard. I torque it down to the actual setting and then go to check if the crank turns over by hand. NO JOY AT ALL?
I have put all my brute force in to it to turn by hand, but does not seem to move at all.
What is the problem here, am I going wrong here, have I messed something up?
All help is really appreciated.
Bobby
Edited by kappa, 30 January 2013 - 04:37 PM.
