Side Trim. What Are You Using?
Scoop77
, Jan 31 2013 05:20 PM
9 replies to this topic
Posted 31 January 2013 - 05:20 PM
I have a white Sprite with black arches and want to replace the trim between them. What have or would you use ?
Thanks.
Thanks.
Posted 31 January 2013 - 08:29 PM
Someone. Any favourite or recommended bits?
Posted 31 January 2013 - 10:21 PM
I usually run archless but when fitting plastic 'special' arches i dont use a side trim...but many use a rubber stripe instead.
Anyhow here the correct part:
http://www.minispare...ng/CZH4316.aspx
Posted 01 February 2013 - 12:04 AM
I too use black rubber trim, but instead of buying new trim, I buy a new door seal instead (which is basically just rubber sill trim with a compressible seal attached on one side). I then fit the new door seal to reduce the chances of future leaks, then strip the compressible side off of the old seal and use that as sill trim instead. One door seal is more than enough both sills and you get a new leak free door seal out of it too.
I've got black Delux style plastic trim between my arches. To stop it pinging off it is held with self tappers at each end.
Posted 01 February 2013 - 05:33 AM
Jaydee thanks. I think I like the look of the original part I found from that link.
Av it, can I see a pic as I'm not sure I'm with you from the text.
Surf, funnily enough it's my experience with this product that has prompted this thread. Mines in the bin.
Posted 01 February 2013 - 08:00 PM
I'm afraid I don't have a pic that explains, basically the black rubber sill trim you can buy is the same stuff as classic mini door seal but without the foam rubber strip on one side that compresses when you close the door. So if you have any old door seals lying around, just strip the foam off of them and use that as sill trim. If you don't, then replace your existing door seals with new (as its only a matter of time until they develop holes/leaks anyway) and then strip the foam section off of your old door seals and use them as rubber sill trim instead. That way you get new door seals as well as trim for your sills. One door seal will give you enough rubber trim to cover both sills though.
Posted 04 February 2013 - 03:22 PM
Got it. Ta ;)
Posted 04 February 2013 - 05:34 PM
sorry to hi-jack this thread but does anyone know of silver coloured rubber trim? i cant seem to find any, its for the same area as the plastic fell off
Adam
Adam
Posted 05 February 2013 - 04:10 PM
Can't help you there but you can get the Wood and Picket stainless bits
