Front Cross Member/inner Wing Support
9 replies to this topic
#1 ukharrisst
ukharrisst
  • 59 posts
Posted 01 February 2013 - 02:56 PM
Anyone know if you can buy the plate that welds onto the end of the cross member to inner wing support bracket or is it a case of making your own?
#2 matty1303
matty1303
  • 197 posts
Posted 01 February 2013 - 03:11 PM
do mean this? http://www.minisport...o_AHP36001.html or the reinforcement for the shock absorber top mount?
If its for the shock absorber top mount , heritage inner wings come with this attached but if you dont need the inner wings I believe you would have to fab this up.
#3 Marcos Controls
Marcos Controls
    Formally known as Polish Marc
  • 105 posts
Posted 01 February 2013 - 03:26 PM
I've just replaced both my inner wings with heritage panels and I had to make them myself. They are easy to do. They didn't come as part of my inner wings. I couldn't find them to buy, but granted I didn't look very hard.
#4 ukharrisst
ukharrisst
  • 59 posts
Posted 01 February 2013 - 03:53 PM
I've just bought a heritage inner wing. Removed the old one yesterday to find the support bracket which covers the end of the cross member/blanks it off so to speak, is badly corroded. Could make one myself but just wondered if could buy for ease.
#5 matty1303
matty1303
  • 197 posts
Posted 01 February 2013 - 04:13 PM
I bought heritage inner wings from DSN Classics and it came with this blanking plate/reinforcement already on it but I suppose there is no harm in adding extra reinforcement
#6 tiger99
tiger99
  • 8,584 posts
Posted 01 February 2013 - 04:41 PM
I am surprised that the inner wings don't all come with the doubler plate attached, as it is nesessary to avoid cracking, and always needs to be replaced with the inner wing because it rusts, as you obviously know. But I can't imagine many people needing the doubler on its own, because to change it the inner wing needs to be removed.
#7 ukharrisst
ukharrisst
  • 59 posts
Posted 01 February 2013 - 05:34 PM
na heritage ones only have clearance holes in where front strut mounting bolts through into the corroded plate which has threaded plate welded on for bolts to screw into.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 01 February 2013 - 06:58 PM
I had to remake two for Project Erm. They did not come fitted as standard and were very easy to fabricate. Don't forget they kick in slightly at the rear to follow the contour of the inner wing.
#9 matty1303
matty1303
  • 197 posts
Posted 01 February 2013 - 07:30 PM
Oh right my bad, I was told different.
#10 Minidarren83
Minidarren83
  • 1,207 posts
Posted 01 February 2013 - 09:19 PM
When I bought my heritage inner wing it came with this plate on the inside not sure why some do and some don't have it maybe it a mk thing
