Su Hs4 Carb Float
6 replies to this topic
#1 Guest_jack mac_*
Guest_jack mac_*
  • Guests
Posted 02 February 2013 - 02:36 PM
hello
As per the title , mine keeps "sticking" and dropping all the fuel all over the floor , so ive come to buy a new one and they all seem to have one pipe on the chamber cover , where as the one ive got at the moment has two ? Will the one with one outlet/inlet work ?
Jack
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 02 February 2013 - 02:54 PM
why do you need the cover ?? It's more than likely the needle valve thats the fault. Could even be dirt in it..
Have you tried cleaning out
Minispares do new valves, floats etc
http://minispares.co...ssic/float.aspx
#3 MRA
MRA
  • 7,607 posts
Posted 02 February 2013 - 02:56 PM
Not ideally no, the extra pipe is a safety overflow.... fuel is best dumped onto the floor than onto a hot engine :-(
What engine do you have, my SU book is to hand to let you know what you should be asking for
#4 MRA
MRA
  • 7,607 posts
Posted 02 February 2013 - 02:58 PM
I read that the OP was buying a new carburettor and not just the float chamber cover ?
#5 Guest_jack mac_*
Guest_jack mac_*
  • Guests
Posted 02 February 2013 - 03:05 PM
it may well be that theres some muck in it not sure and im not the competent with carb it baffles me so id rather do a straight swap , it a standard 998 (1988 Jet Black ) with a stage one kit
#6 MRA
MRA
  • 7,607 posts
Posted 02 February 2013 - 03:12 PM
Then you are possibly looking for a FZX1415 carburettor....
However its not too difficult a job just to do the float valve, after all you must have removed the carb in the first place !!
#7 Guest_jack mac_*
Guest_jack mac_*
  • Guests
Posted 02 February 2013 - 03:14 PM
ok cheers , nope i bought it with the stage 1 already on ;)
