Mini Problems Under Load
Posted 02 February 2013 - 03:49 PM
recently when accelerating under load she misfired a few times, then the revs drop to zero, both warning lights come on and I have no power whatsoever.
I have replaced the points, condenser, distributor cap ht leads but there is black oily residue on the spark plugs.
Help please, im a bit afraid to drive it
thanks all
embeded
Posted 02 February 2013 - 04:30 PM
Posted 02 February 2013 - 04:34 PM
If it is running rich, it could be various problems. As for the plugs being oily, that could be unburnt fuel, mixing with the soot on the plugs , ( looks like oil ) .
Im sure more answers will come along soon.
Posted 02 February 2013 - 05:03 PM
Posted 02 February 2013 - 06:30 PM
Posted 02 February 2013 - 06:52 PM
Posted 02 February 2013 - 06:57 PM
Posted 02 February 2013 - 08:49 PM
It could be a rich mixture, it could be the ht leads or a cracked dizzy cap.
new plugs are only £10 for 4.
Posted 02 February 2013 - 08:54 PM
Sounds like a stuck needle valve flooding the carb. Is it an HS4?
Posted 03 February 2013 - 06:44 AM
Posted 03 February 2013 - 10:27 AM
Posted 03 February 2013 - 11:07 AM
Do you know where the oil should be up to?Also check to see if you have any oil in the dashpot, this will cause apparent misfire under load and mess with the fuel mixture.
That sounds like a plan, i will give that a go today, and yes its an hs4
