Dead Battery
6 replies to this topic
#1 BVY
BVY
  • 639 posts
Posted 02 February 2013 - 09:51 PM
Evening all,
I haven't driven the car since Monday and this morning the battery was dead as a dodo. Not even a click of the starter!
It's a brand new battery and I fitted a new earth strap at the same time.
I'm just wondering what you would suggest investigating. I guess it must be a dodgy earth somewhere or maybe the alternator? I can't believe a new battery could die in 5 days when it's not even cold!
Attached File  IMG_1240.JPG   83.45K   18 downloads
This was the old battery. What causes that greenish gunk to build up?? Could it be a clue as to what the problem is?
Thanks in advance
#2 OfMini&Men
OfMini&Men
  • 284 posts
Posted 02 February 2013 - 09:54 PM
That battery is in general terms F**ked the green stuff is hydroical acid remains IIRC something isn't right with that battery at all
dispose of it properly and go get a new one.
#3 BVY
BVY
  • 639 posts
Posted 02 February 2013 - 09:55 PM
Oh yeah, and my horn stopped working the other day. Just wondering where the fuse is and what else to try.
#4 BVY
BVY
  • 639 posts
Posted 02 February 2013 - 09:56 PM
I already replaced it. I just thought that might be a clue to why the new one died...
#5 richw911
richw911
  • 2,084 posts
Put a voltmeter on the battery with the engine running you should see 14v approx could be a fault with the alternator -also check the wiring to it.
#6 richw911
richw911
  • 2,084 posts
Posted 02 February 2013 - 09:57 PM
Check the purple wire going to the horn as a first step it could be corroded
#7 BVY
BVY
  • 639 posts
Posted 03 February 2013 - 09:10 PM
Thanks! I'll obtain a volt meter then.
My car has had a giberglass front put on so has had everytging at the front re-wired. So none of the wiring is original in that area.
Probably the cause of the problem!
Hopefully I'll get to the bottom of it anyway.
