Benefits Of Ram Pipes?
Posted 07 February 2013 - 09:20 AM
Just want to know the benefits of ram pipes
Thanks Jack
Posted 07 February 2013 - 09:33 AM
Posted 07 February 2013 - 09:41 AM
Posted 07 February 2013 - 09:50 AM
There are various different types.
The principle is that the ram pipe decreases the affects that air trying to go round a sharp edge will create, namely the Vena Contracta, the ill effects of poor flow are reduced power, torque and response...
Take a look at the following link you may find it interesting
http://en.wikipedia..../Vena_contracta
Posted 07 February 2013 - 10:37 AM
Jack
Posted 09 February 2013 - 02:56 PM
Some if they have a good radius, but a sharp edge can create an even lower air flow, due to them amplifying the Vena Contracta
And even if you get a really good item if its up against the filter housing or bulkhead etc.... then forget it unless you are going to modify these parts.
Posted 09 February 2013 - 03:54 PM
Posted 09 February 2013 - 04:46 PM
Posted 09 February 2013 - 04:56 PM
Posted 10 February 2013 - 10:32 AM
Posted 10 February 2013 - 10:47 AM
That said, i also believe the 28/36 is a progressive choke system, so part throttle only 1 choke will be operated till you floor it... i dont think the ram pipes will lend them particualy well to this application (would you require 2 different length of ram pipes??)
Posted 10 February 2013 - 10:56 AM
Different lengths on various carbs, ie tuned lengths do work on some engines, not sure about the A series, could be worth a try...
Thanks Dilligaf for the info above, how much room above the carb to bonnet is also important, its all very well having the best flow potential into the carbs ...but if the bonnet gets in the way, youve just wasted loads of cash and time.
Posted 10 February 2013 - 11:02 AM
This kind of set up would cause alot of dirtied air anyway (with the joining up and then splitting away of air to different paths), hardly ideal for a performance set up but good for the eco drive as will also allow for greater mix and swirl
Edited by mini93, 10 February 2013 - 11:02 AM.
Posted 10 February 2013 - 11:15 AM
The Vena Contracta in this case (without the ram pipes) will cause reduced torque, even if the engine is trying to "pull" the air in, ie higher vacuum.
For anyone confused, dirty air is turbulant air, it is not unfiltered air.
Posted 10 February 2013 - 11:17 AM
You can get the thinnest KN (1.25" iirc) on under the bonnet, if you remove the domed nuts on the filter and replace with normal ones. This does depend a lot on which manifold you use, the best for power (supposedly, I didn't notice a difference) is as the above link. i.e.. with the carb at right angles to the engine. But this type wont fit without serious modes to the bonnet. The manifold to use with a mini is the type that sits the carb parallel, ie. with the float chamber pointing forwards.
In that case you are going to be hard pressed to get a decent ram pipe to work, there are stubby types but they are more for show. The longer they are the higher the torque increase to an extent, not forgetting the laws of diminishing returns.
