First Motion End Bearing Removal
Posted 08 February 2013 - 09:53 PM
I am having trouble getting it off. The haynes manual says to use a puller, I have one but its too big, or to use two screw driver...How??
Am I right in the bearing should not be to hard to remove, But mine does not budge! (And yes I have removed the circlip!)
Any ideas, A bit of heat?
Posted 08 February 2013 - 09:58 PM
http://www.toolstati...ller Set/p79243
Hopefully this helps mate
Posted 08 February 2013 - 10:04 PM
Posted 08 February 2013 - 10:27 PM
Posted 08 February 2013 - 10:44 PM
they are normally easy to remove, cant see why yours wont budge
I have no idea either :/
25 Years of crap? The outer race was a total pig to get out!
Posted 08 February 2013 - 11:42 PM
I find whacking them so the bearings come off the middle bit, then using one of these works well.
http://www.machinema...1&TC=SRC-puller
failing that gently grind a flat on the side of it almost down to the shaft ( pausing to let it cool) when your pretty close to being through pull it off, it will com much easier.
Posted 09 February 2013 - 02:43 PM
Posted 09 February 2013 - 07:04 PM
Knock back the locktab and undo the nut - you'll run out of thread eventually but it starts to pull the race off enough to get a puller behind it.
good idea.............
Posted 09 February 2013 - 09:51 PM
Ill do it tomorrow!
