Six Pot Kad Discs Question
38 replies to this topic
#1 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 09 February 2013 - 10:27 PM
Ok just a quick one.
Had kads big disc on my racer for years now, on the discs there are grooves ,mine have always faced forward, just surfing the web and found a photo of some on a bloke building race minis and he has his the other way around.
see link.
http://www.racecarsd...ck_day_car.html
which way is correct?????????
#2 mini-geek
mini-geek
  • 1,169 posts
Posted 09 February 2013 - 10:31 PM
I've asked this before and the conclusion was it didn't matter....
And to confirm this I swaped mine around to try it.. They worked better for a few miles while they bedded in but are in reality no different...
#3 jaydee
jaydee
  • 8,565 posts
Posted 09 February 2013 - 11:08 PM
We've been discussing this last summer:
http://www.theminifo...or-orientation/
#4 summs116
summs116
  • 372 posts
  • Local Club: Mini 7 racing
Posted 09 February 2013 - 11:38 PM
I've just fitted my kad 4 pots direct from kad and the disc was marked r/h. And l/h on the boxes and discs them selves and mines fitted like his rebuild
Now you got thinking
#5 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 09 February 2013 - 11:42 PM
Well just to be sure im going to call KAD monday,
Dont want to fu k up my new discs or pads. There not cheap you know.
Mine are fitted opposite to the photo in the link.
I hope im correct dont want to swap them round.
Ill update asap.
#6 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 10 February 2013 - 05:48 AM
the groves are meant to face outward.. but like the rest of the lads said above.. not much difference otherwise..
#7 MRA
MRA
  • 7,607 posts
Posted 10 February 2013 - 10:14 AM
Yes there is a difference, the correct way and the grooves will gently slide across the face of the disc, the wrong way and they put extra strain on the disc and pad with a higher possibility of cracking said disc or chipping the pads, its easy to machine straight lines, its not so easy to machine curved lines its done for a reason.
A few years ago, we looked in to machining names instead of standard grooves into discs.... ie 1275 GT or wookey you name it we where asked, however the safetyimplications range far and wide....
The picture of the space framed Mini is correct, they should be sweeping and NOT scything across the face of the pad.
#8 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 10 February 2013 - 10:44 AM
the grooves are also one way for cooling purposes so if they are the wrong way round then they wont be as efficient and you will loose braking performance especially when racing, wont be as noticeable on the road but still a factor
#9 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 10 February 2013 - 11:00 AM
Ok thanks you guys lots of different opinions here, these were fitted opposite to to the photo by Green and White mini spares a few years back, I would have though they would certainly know which way to put them but ill get all the info from kad on Monday.
On saying this I have noticed the pads chipping away slightly but never really thought much of it!
#10 MRA
MRA
  • 7,607 posts
Posted 10 February 2013 - 11:04 AM
Brakes work by energy conservation laws, the more material you have the more braking potential you have......
The grooves dont really improve cooling, the original Metro had vented discs which had curved vents, these increased airflow and yes allowed the discs to cool quicker
The grooves are there to remove the very thin layer of "cooked" pad material thus reducing the chances of fade.
#11 mini-geek
mini-geek
  • 1,169 posts
Posted 10 February 2013 - 11:35 AM
Just to make this more confusing, if you have vented discs some have straight vents some have angled...
#12 MRA
MRA
  • 7,607 posts
You are partially correct...
After 86 all discs fitted to metro's where vented and the vents where straight, this was a cost down exercise by Rover.
The Mk1 MG Turbo had curved vents they where handed for this very reason.
#13 MRA
MRA
  • 7,607 posts
Posted 10 February 2013 - 11:37 AM
That's because its cheaper to produce straight grooves, we use CNC machines and for us its just a simple program, however if you machine the grooves on a conventional milling machine then its almost impossible.
#14 mini-geek
mini-geek
  • 1,169 posts
Posted 10 February 2013 - 11:39 AM
Sorry I'm talking about the vents in the discs not the groves..
#15 MRA
MRA
  • 7,607 posts
Posted 10 February 2013 - 11:44 AM
The vents are the section between the 2 friction faces of the disc, and so was I :-)
Grooves are on the friction face or surface
