Lacquer Help Please
wilz1234
, Feb 13 2013 10:20 AM
9 replies to this topic
Posted 13 February 2013 - 10:20 AM
Hi guys,
Currently half way through painting the car and now have a nice gloss finish on all the panels and now have got to a point where I can lacquer the car. Do I need to sand the paint down before applying lacquer? As in, do I need to rough it up so it sticks to it, or do I want as shiny surface as possibly before spraying the lacquer?
Posted 13 February 2013 - 10:37 AM
No need to sand down before applying lacquer, just refer to manifacturer reccomendations about dring time between paint coat and lacquer.
What do you mean by shiny surface? it doesnt have to be shiny, lacquer is for metallic paint and the likes..which are a bit dull before lacquering..if you're going to lacquer a solid color the paint will fade in very little time.
Posted 13 February 2013 - 10:38 AM
What sort of paint have you used?
Posted 13 February 2013 - 10:43 AM
I've used aerosol gloss black on the roof, and gloss white everywhere else.
Posted 13 February 2013 - 11:19 AM
So is lacquer not needed on a solid colour?
Edited by wilz1234, 13 February 2013 - 11:21 AM.
Posted 13 February 2013 - 11:30 AM
If the paint is a base coat regardles of it being a metallic or solid colour it needs laquer.
all laquers should be sprayed on within a few hours of painting the base colour, if left to long you will need to repaint the base colour.
Posted 13 February 2013 - 11:44 AM
Thanks midridge2
The roof is currently painted with this:
http://www.halfords....tegoryId_165495
And the rest of the body with this:
http://www.halfords....tegoryId_165505
Will these require lacquering?
Posted 13 February 2013 - 11:53 AM
The gloss black is fine without the need for laquer, the polar white has no mention about it being a base coat but check the can.
Posted 13 February 2013 - 12:41 PM
The white is fine too. Only metallics from Halfords will need lacquer
Posted 13 February 2013 - 12:43 PM
Excellent
Saves a lot of time
