1997 Mini Cooper Srs Light
8 replies to this topic
#1 oltonlad
oltonlad
  • 2,401 posts
Posted 13 February 2013 - 11:02 AM
Hi all, has anyone had the problem of the srs light staying on all of the time?, if so how did you remedy it? I thought I'd ask first before I start messing with it so I know where to start looking for the problem.
Cheers.
#2 bcjames
bcjames
  • 2,737 posts
Posted 13 February 2013 - 11:31 AM
Unplug the battery half an hour before you start this, then check the connections in the rear pockets, under the rear seat, and behind the airbag. It's likely one has just worked lose or slightly damaged, particularly the one in the steering wheel. Certainly the first thing to check.
#3 oltonlad
oltonlad
  • 2,401 posts
Posted 13 February 2013 - 11:43 AM
I'll try that, many thanks :-)
#4 Alex_B
Alex_B
  • 4,573 posts
Posted 13 February 2013 - 11:54 AM
watch out though using a multimeter on the SRS circuit can deploy the airbags or seatbelt pre-tensioners which is nasty!
all SRS wiring should be yellow too :)
#5 oltonlad
oltonlad
  • 2,401 posts
Posted 13 February 2013 - 12:02 PM
Thanks guys, the cars only done 22,000 miles from new so it shouldn't be anything too drastic (I hope)
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 13 February 2013 - 12:05 PM
one common fault is the clock spring, (rotating couple that connects the airbag in steering wheel with the rest of the circuit) which is about £150 new from minispares, so if you dont find a fault elsewhere would be an idea to check that next :)
#7 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 13 February 2013 - 12:32 PM
does your horn work? If not then look at the rotary coupler as alex suggested.
#8 stevedx
stevedx
  • 1,312 posts
  • Local Club: brighton mini club
Posted 14 February 2013 - 04:43 PM
mine still does it too, the srs light is now on permanent
#9 Noris8322
Noris8322
  • Just Joined
  • 201 posts
Posted 14 February 2013 - 06:14 PM
How about putting a small piece of tape over the light? lol
Sorry I couldn't resist!!
