changing brake bias
23 replies to this topic
#1 pikey7
pikey7
  • 3,824 posts
Posted 11 April 2006 - 08:37 PM
Is there some way I can modify or replace the FAM7821 to allow me to have an adjustable brake bias?
I know I can fit an extra prop valve inline in the rear system (away from the drivers seat), but if I can do it one unit.....
#2 Jammy
Jammy
  • 25,397 posts
Posted 11 April 2006 - 09:26 PM
I've heard you can modify the FAM valve to make it adjustable as well, although not sure on the method?
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 April 2006 - 09:39 PM
The FAM7821 valve is tricky. No-one actually knows exactly what it does. I was intending to fully test one but I never got round to it. I think it's actually a delay valve rather than a brake bias valve, it doesn't appear to do any biasing in the normal sense in that is messes up all the calculations that you do when working out line pressures based on cylinder sizes.
I've never heard of a way to alter it but there may be a way that some people use.
#4 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 11 April 2006 - 09:48 PM
is the valve you are talking about the T piece on the rear subframe?
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 April 2006 - 09:50 PM
No, the large two circuit brake valve on the bulkhead. The tee-piece is just a tee-piece usually.
#6 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 11 April 2006 - 09:54 PM
i had one that didn't work once.... was fine as long as you didn't use the last 1/2" of brake travel or it would lock the rear end up.. never replaced it because it was actually good fun when you got used to it. this is why most junctions in witney still have a black figure 11 painted on them..
#7 pikey7
pikey7
  • 3,824 posts
Posted 11 April 2006 - 10:25 PM
it just comes apart with that big nut on the end right? I have a spare I may have a play with to see what it does. Its only £30 of ebay junk anyway..... ;D
I had a feeling it wouldn't be as simple as just tapping a hole and adding a bolt though. Nothing is ever that easy.....
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 April 2006 - 10:49 PM
I think all the important bits are under the crimped on cap at the other end. Since there's no re-build kit for these though I've never had reason to open one up so far so who knows what's inside it?
#9 pikey7
pikey7
  • 3,824 posts
Posted 11 April 2006 - 10:50 PM
I guess we'll find out tomorrow then! I'll take the camera......
#10 miniboo
miniboo
  • 9,327 posts
Posted 12 April 2006 - 06:09 AM
thank god it is only a t piece because i gave a spare one i had to a mate to use on his kit car.
#11 Wil_h
Wil_h
  • 3,244 posts
Posted 12 April 2006 - 06:59 AM
Actually the earlier single line systems had a 'biasing' T-piece on the rear subframe, like this:
http://www.minispare....aspx?pid=36159
It's these that can be modified to be adjustable.
#12 Jammy
Jammy
  • 25,397 posts
Posted 12 April 2006 - 08:41 AM
Ahh, I see, cheers Wil, don't suppose you know how to modify them do ya?
Also have a spare FAM7821....
Edit: Thought I'd have a quick look on Claver's Corner on MiniSpares. Found this.
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 April 2006 - 10:35 AM
You have to make sure you're modifying the right one if you are working on the rear bias valve. The very early Cooper had a brake intensifier at the rear rather than a biasing valve which had some form of additional cylinder inside it. Modifying that can give nasty results.
But in the vast majority of Mini's it's just a tee-piece.
Edited by Dan, 12 April 2006 - 10:35 AM.
#14 pikey7
pikey7
  • 3,824 posts
Posted 12 April 2006 - 06:54 PM
Sorry guys, no pics today (I had a little problem with the turbo on the Porsche.... As in blew it up! ;D ) Will get on it tomorrow (plus it gives this thread a little bump if anyone else has a bright idea on how to do it!)
#15 Jammy
Jammy
  • 25,397 posts
Posted 13 April 2006 - 09:25 AM
This was posted on 16VMC in a similar thread.
