I have a 998, with...
Rebuilt standard carb (SU HS4), standard air filter with K&N element, new plugs, leads, dizzy cap, rotor arm, points condenser and starter coil, new radiator, thermolstat, throttle and choke cable, engine temp sender, new exhaust manifold gasket. And a silly exhaust (whith no holes). Recent oil change, not changed oil filter.
The problem:
I can run her around town all day, and she'll be fine and won't miss a bit. The problem is on motorways.
She'll really struggle to get up hills, 55 tops, and struggles at times when I put my foot down to over take.
When I pull off the motor way, I have no power. When i put my foot down, the rev needle just blips up for a microsecond, and the I get no power, and it takes forever to build the revs up. After a while again of normal road driving, she'll return to normal. But as soon as I come off the motorway she's barley drivable.
Once when I piulled off the motorway and dipped the clutch, the revs dropped to 500rmp!
From left to right, the spark plugs are colourd white, black, white, black.
Down hill she'll do well over 90mph!!
I'm really at a loose end now, any help would be gratley appriciated.
Ben
Edited by BenCoul, 16 February 2013 - 02:08 PM.
