Desperate For Help
Posted 16 February 2013 - 02:36 PM
It runs like #@#? It doesn't pull, it missfires backfires and goes 15 mph top speed it's really bad!
Do I need to alter timing? And how on earth do I do this?
HELP MEH!!
Posted 16 February 2013 - 02:57 PM
Posted 16 February 2013 - 02:58 PM
my only option is ht lead on right plugs ??
Posted 16 February 2013 - 03:00 PM
Are you also sure you haven't mixed up the plug leads as well(or accidentally knocked one off)
Posted 16 February 2013 - 03:02 PM
Also how hot is the coil getting when misfire happens?
Posted 16 February 2013 - 03:28 PM
Posted 16 February 2013 - 03:29 PM
id love to try help but not really sure what you have fitted.
It's a powerspark electronic ignition module and non ballast coil
New coil should have the new 12v feed wire you have fitted on the + terminal and the wire from the trigger head you've fitted marked + connects to the same coil terminal, and the other wire from the trigger head connects to the - terminal of the coil. So assuming your leads are in the correct place (did you remove cap/coil?) If thats all correct then you now need to check the timing. The only way really to do that is with a timing light, which you would run the engine at idle speed and check how far before TDC your timing is currently set, I suspect the trigger head is in a slightly different position on the bass plate causing the timing problem.
While I was writing this you've stated you don't have a timing light, so maybe someone near you has one here or its a garage job to get it spot on.
Edited by KernowCooper, 16 February 2013 - 03:30 PM.
Posted 16 February 2013 - 03:30 PM
Posted 16 February 2013 - 03:32 PM
Right you have said you've put a new feed wire in which is 12v and looks like a new coil which is non ballasted, so lets start again.
I did remove the cap bit I numbered the ht leads and put them back in the same order. I screwed the baseplate in where the other were, and the rotar arm. I'll try sort a strove light out
Posted 16 February 2013 - 03:33 PM
Posted 16 February 2013 - 03:38 PM
yesSo just to confirm, is the coil a non-ballast unit suitable for 12V direct feed?
Edited by jmmini, 16 February 2013 - 03:38 PM.
Posted 16 February 2013 - 03:40 PM
Posted 16 February 2013 - 03:47 PM
Once the engine is running correctly and up to temp, the optimum timing is reached by bringing the engine speed up to between 3000 and 4000 RPM and setting the MAXIMUM DYNAMIC advance to about 32 BTDC. Then return the car to idle and test drive it. If you hear any pinking under load, turn the timing "back" (retard) in 2 degree steps until driving under load produces no pinking.
Obviously refit vac pipe to carb when finalised timing and on road tests
Edited by KernowCooper, 16 February 2013 - 03:55 PM.
